SR20 DOC Race manifold, Tomei m7960 turbo, Turbosmart Ultra-Gate 38mm
Parts are located in Alberta, CANADA. Shipping is obviously available to anywhere in North America.
---------------------- It's going up for sale, I'm going v8. With this setup I made 355hp/298tq on 14psi with 550cc injectors. DOC Race manifold: DOC Race makes one the highest quality manifolds you can purchase on the market today. "The DOC Topmount manifold can still be used for streetable vehicles, but is solely designed to make maximum horsepower and allow you to fit much larger T3 frame turbos then the traditional T25 manifold (provided with a t25-t3 adapter). D.O.C. still applies their elaborate porting process to complement maximum flow within ALL of their manifolds." T3 Flange 2 bolt 38mm Wastegate Retains AC SOLD ![]() ![]() --------------------------- Tomei m7960 turbocharger: I friggen' love this thing! Quick spooling, puts down awesome numbers and looks amazing under the hood. About 15k, shaft play is damn near identical to when it came out of the box. Good seals, no nicked fins. The internal wastegate has been tacked closed on the outside of the turbine housing. If the buyer wishes they can attempt to grind the tack off and use the internal gate as intended (I recommend keeping the turbocharger externally gated). I'll also include with the turbo stainless lines, and -AN fittings for both coolant and oil feed/drain. Coolant is -4 and -6, oil is -4 feed and -10 drain. http://www.enjukuracing.com/products...n-sr20det.html $sold ![]() ![]() ![]() ![]() ---------------------------- Turbosmart Ultra-Gate 38: 38mm external wastegate. 2 bolt style. 7psi spring. These are shorter than Tial wastegates, making installation into tighter area much easier. $sold ![]() ------- -------------- ------- WHOLE PACKAGE: $1100 Last edited by KingSpence; 11-05-2014 at 11:24 PM.. |
For $550 you get what you see in the picture, plus the internal wastegate if you want to try and make it work. The stainless elbow (I think I still have it), that blue coupler, and the Tomei badge and stickers I have from the original package.
For $600 you get everything above, plus I'll toss in the -AN oil feed and drain lines, -AN coolant feed and drain lines, and respective block -AN fittings. ![]() |
