Old 11-01-2014, 08:06 PM   #5
_rods13
_rods13 is an unknown quantity at this point
Originally Posted by robinsone View Post
I had a somewhat similar problem. So my IACV was clogged. The engine wasn't getting enough air and was idling funny, running rich and bogging down. When I ran it for awhile and then stopped it, it wouldn't start again, at least immediately. Once I let it sit for a bit, and the excess fuel dissipate it'd start right up. Not sure if this is your problem but it would be a really easy fix.
Find your IACV valve, not hard to take off. Clean it with intake cleaner or equivalent, letting it sit for awhile to dry out. Re-install and see if that helps, if it doesn't move on to something else.
I assume you are running a SOHC KA24E though.
wow yes it also bogs and after a while itll be fine so I will try this!! and yes i forgot to include that it is the KA24E
_rods13 is offline   Reply With Quote
fuel, nostart, pressure, s13, timing
