Timing SHOULD be 15 Deg btdc.
What you want is ignition base timing. You're checking timing with ecu in control Simple, Warm engine up,turn motor off, disconnect TPS ( throttle position sensor) with engine off, start up engine, check timing with gun, play with the CAS ( crank angle sensor) set to 15 deg, secure CAS, snap throttle ( quick rev), let idle .. adjust idle if needed via IAA on intake manifold. |
