#241 |
![]() Join Date: Oct 2007
With stock p11 cams you should be find !!! I saw stock bottom ends with vvl conversion done before !!!
AV FABRICATION Built thread sr20vet s14 http://zilvia.net/f/showthread.php?t=535574 |
#242 |
#243 |
Banned from the Marketplace
Assuming most of you guys are rocking high HP SRs with multi-plate clutches, any of you guys using the Mazworx hydraulic release bearing kit? I recently switched from a OS Giken twin to an Exedy Triple on my SR22VET and need to find a way to release the clutch without having an NFL linebacker's left thigh haha
#244 |
The only thing I can add is it is suppose to help with High Rpm shifts.
I am rocking an Exedy Twin, but utilizing the factory slave/fork setup.
#246 |
![]() Join Date: May 2006
you guys have any flow analysis for the intake manifold?
I would like to see it.
#247 |
![]() Join Date: Jun 2003
Trader Rating: (130)
Autotech do you have rough price on that manifold? Having a plenum that clears the hood would sure help me out.
#248 |
#249 | |
![]() I have a feeling it is ceramic/high temp coated ![]() ![]() |
#250 | |
I am not denying that thermal coating headers is a great idea, my point is that it makes a minute difference at best on a car like this and would still slightly burn/melt the carbon on the hood and heat up the brake lines and fluid reservoir regardless of what coating he has on them. A stainless blocking plate or 2 with gold heat tape or asbestos heat blanket would be best IF this was a serious problem on the car, and obviously after spending the time and $80-$100k building this car, he will make sure that is done correctly regardless of his methods. The fact is you are more than likely a typical zilvia troll rocking some T2 turbod SR with a single disc clutch thinking you're the hottest shit around, and it would be appreciated that you only comment if you have valuable input with regards to the question at hand or any viable experience with a build of this magnitude in the past. Thank you. |
#251 |
Can you please show me the service applied to "polish" a manifold??
And no, Not a T2 troll. I have had several chassis, with the fastest being a 98 SE-R with a honkin Garret turbo, half cage, wilwoods, etc cracking 140+ MPH consistently at Summit Point Main front sttraight that has chased down several Hoosier Shod C5 and C6 Z06s ![]() ![]() Please tone down the anger. You sound much more like a butt hurt Zilvian than I do throwing around your claimed"achievements" and Indy car knowledge mind you.......... This is what I have found in my quick search http://www.cycleworld.com/2013/11/25...header-polish/ |
#252 | |
TRD 4AGE Atlantic example ![]() USAC midget example ![]() Other angles http://i911.photobucket.com/albums/a...pse1954cbf.jpg and again http://i911.photobucket.com/albums/a...ps7ec08321.jpg No anger here, just pointing out your rudeness of a simple question while your only "credentials" are owning a moderately quick nissan sentra at some point in your life. The exhaust manifold on IMarvin240's looks rather shiny, meaning it is either polished or some quality high temp coating as opposed to the run of the mill dull coatings you see on most manifolds on these cars. I inquired to ask HIM as I am interested. Thanks |
#254 |
My day job is lead engineer building small scale turbines, heating elements and ICE. SO I do have a little bit of experience in exhaust materials. Also, to confirm, Indy car and F1 uses a specific type of coating and not a "polish" compound.
Your idea of polishing and mine are somewhat different, hence my questioning. Also, last I checked, the Indycar and F1 headers are inconel with a "coating" and not a polishing as you stated. It starts out as a "polished" or reflective surface, but quickly turns into a dull hue as once inconel is heat cycled (the first pictures you posted is a VERY good example of this effect happening, as you can see the "reflective" coating slowly loosing is shine) it forms a coating or barrier around the metal which protects it from abrasion and insulates it. Here is a detailed picture of the Renault from the V8 era (I had a chance to go into the pit garages at Montreal a few years ago) Renault (if I remember) F1 car from a few years ago ![]() Below is a gentleman that does the Indycar Manifold coatings and you can see, one of the coatings is actually reflective (which can easily be descerned as polished) ![]() The link to the gentleman above https://www.rbracing-rsr.com/coatings.html And lastly, just because I have a "sentra" means nothing to my experience level. Cheap, easy fun was the goal and that's what it attained ![]() |
#256 |
#257 | |
First and foremost the first picture I posted is NOT an inconel coated header with anything applied to it in the slightest. I know this because that is my Toyota Atlantic car and I polished the manifold myself from a bare stainless. Zero coating of any kind, just polishing. Hence why it has turned gold as mentioned earlier. Second, I am not claiming that all indy cars are one way or another or that one method is better or worse. I clearly stated that many are coated, including all current DW12 cars done by Howerton Products, as a spec thermal coat for all in the series (and has been for some time) and requires re-coats at mileaged intervals in order to not melt the exhaust valves (does not have to do with keeping engine bay temps down as your point alluded to. While, YES some of the 15 year old v8 indy car headers (including your pictured oldsmobile V8) are thermal coated, many of them are not, as it is not needed with NA engines in the slightest. You seem to be stuck on the fact that there is a thermal coating available that is shiny, while yes, I have agreed with you on this point. Multiple times. I acknowledge the fact that these coatings exist, and have driven many racecars with them. However, point being, cars like ours that are glorified street cars with mild engines DO NOT require these coatings, so there is no sense in bashing my inquiry to Imarvin240. Imarvin240 I greatly appreciate your response and it is nice to know! I will contact TF and see if they can point me in the direction of their coater. Really like how that one turned out! |
#258 |
![]() Join Date: Oct 2004
![]() ![]() ![]() ![]() ![]() ![]() ![]() btw whats wrong with having an SR and ripping around having fun? dont be a snob
Drift Indy |
#259 |
#260 |
Sorry for being a hardass JSimpson. We both know a thing or two, so no hard feelings
![]() My mistake on the Atlantic. What I was referring to is heat cycling and what it does to a "reflective" coating and not that an Atlantic Car uses inconel headers. It's just when someone on Zilvia uses the word "polishing" and "exhaust" I think of bad things........ For clarity, the current IndyCars use strictly inconel, coating and Titanium exhaust shields. Below is a picture from the 2013 season and the inconel header ![]() Below is a Chevy from the 2013 season. You can see the obvious "hot" coating on the turbine outlet and the heavy use of titanium exhaust wrap (looks to the be same stuff WRC and WEC cars use) ![]() |
#261 |
However, I simply cannot agree with the fact of our street cars NOT needing coating. From my experience, any form of heat management is welcomed
Underhood temps going to a ceramic coating then to a full titanium shield, yielded a few hundred degrees drop in engine bay temps on my "street" vehicle and also gave me a few points in Compressor, Radiator and intercooler efficiency since the amount of radiant heat dropped some 10 fold Where the manifold and turbine housing were a several hundred degrees F without coating, it was only a little over 250 F with the ceramic coating to a little over 120 F after a full 20 min session in the middle of summer after a titanium shield was installed. This also translated into meaning all underhood components having an increased life span. Considering the industry I work in, I am HUGE stictler for heat management and see zero downsides to it regardless of it's a glorified street car or a full bore open wheel rig. |
#262 |
/\/\/\ can you guys go start your own "polishing and coatings" thread instead of derailing this one?
#264 |
![]() Join Date: Dec 2010
Trader Rating: (18)
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 18 reviews
What information are you looking for? A lot of the guys in here, including myself, have built some decent VE engine setups.
https://instagram.com/eck_matthew/ |
#266 |
Under Suzuki just smashed the Tsukuba record 51.127 with that set-up ^^^^
#268 |
Id say roughly 3-5k depending on the route you take and what's purchased new. For some that seems excessive when you can buy an RB that can handle more power, but I'd say it's far less than the 2J swaps.
#269 | |
I'm damn near $10k into mine, but I also bought new cp Pistons and manley rods, N1 cams, bnib p12 valve cover, and $2k in WPC treatment. |
#270 |
Trader Rating: (18)
Exactly! It all depends how crazy you go with the build. I'm over 100k into the overall build of my car, with roughly 50k of it being in my engine bay (most of the parts had to be custom made). I went more overboard then I planned to, but overboard is usually how most builds end up. Luckily I'm just about finished up with my build. Brndck, any photos of your setup?
