Old 01-19-2015, 01:01 PM   #1
Silvi
Silvi is an unknown quantity at this point
PS switch/brake fluid connectors
Im working on my loom and trying to remove any useless connector/wire.
I wonder if "power steering oil pressure" and "brake fluid level switch" are critical connectors for proper work. Im trying to avoid as much as possible from removing any critical wires..just want hear the engine start after this annoying work
Silvi is offline   Reply With Quote
Old 01-19-2015, 01:44 PM   #2
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
no they aren't important to starting the motor. P/S pressure sensor is for idle up when you turn the wheel, and Brake fluid level is for gauge cluster.
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 01-19-2015, 03:37 PM   #3
KoukiMonsta
KoukiMonsta's Avatar
KoukiMonsta is a well-known jackass
correct, I deleted both from the last harness I made.
I will note if you have all the factory PS stuff It may be worth keeping. I re-did all the lines and got rid of the provision for the switch/sensor which is why I decided to delete the wiring behind it.
@UpshiftEngineering
KoukiMonsta is offline   Reply With Quote
Old 01-19-2015, 11:53 PM   #4
Silvi
You mean worth keeping to avoid idle problems?
Old 01-20-2015, 10:31 AM   #5
KoukiMonsta
Correct, to retain features that engineers originally designed to optimize engine 'performance'
@UpshiftEngineering
Old 01-20-2015, 10:37 AM   #6
Silvi
So I'll replace the line to high pressure line, problem solved
Thanks guys!
