Old 04-09-2015, 07:25 AM   #1
StoopidLoose88
StoopidLoose88 is an unknown quantity at this point
Overfender Guide
Ok I've searched the forum and google and have not found the concrete info I'm looking for. What are all the options for rear over fenders(in my case for an s13 coupe, but I'm fine with someone who has knowledge about s13 hatch/s14/s15 posting so it may help someone down the road!). So far the ones I know of are the Origin overfenders(I'm sure there are many other brands and options I'm missing.)
Origin Type 1 (Available in 50mm)
Origin Type 2 (Available in 50mm)
Origin Tatakadasi fender pull (Available in 30mm/50mm)
I have no clue what any differences are in these three. After doing some image searching on google I found mixed results but the trend seemed to be:
Origin Type 1 - Smooth sides
Origin Type 2 - Stepped sides or Sides with a fine body line in them (not sure which one)
Origin Tatakadasi fender pull - Appears to be type 2 with a molded 'roll' to the fender
If you add please try to put your info in this format and i will add it to the original post
Brand and name of overfender(Sizes its available in)
What s-chassis it is for
Price
A description of its physical appearance/what makes it different
Hopefully we can get some concrete knowledge on this subject and possibly get this to be a full "Overfender Guide" sticky for all the s chassis'
Overfenders Guide:
S13
Origin Lab type 1(50mm)
s13 coupe/hatchback
$306
Thin body line(similar to chargespeeds), follow window/trunk lines, wrap around taillights
Origin Lab type 2(50mm)
s13 coupe/hatchback
$306
Stepped side, follow window/trunk lines, wrap around taillights
Origin Lab type 3(55mm)
s13 coupe/hatchback
$395
OEM body line, flared fender, follow window/trunk lines, wrap around taillights
Origin Lab Tatakadasi fender pull(30mm/50mm)
s13 coupe/hatchback
$306
Appear to be smooth side with flare around wheel well(simulated fender roll), follow window/trunk lines, wrap around taillights
Extreme Dimensions "Gt-R" style/Duraflex B-Sport(50MM)
s13 coupe
$299
Which would be a copy of Origin Type 2, fitment was surprisingly good, they are thin and VERY flexible. Only Issues i have with them are:
1. They do not have the body line (the little bead in the middle of the body)
2. The gas filler cap area needs a bit of work, for the cap to fit (not a big issue though)
Overall very pleased with them. -japslapsilvia
VIS Drift X(30mm)
s13 coupe/hatchback
$249
Look like they follow window/trunk lines, wrap around taillights and have OEM body line through them
chargespeed(50mm)
s13 coupe/hatchback
$499.00
top notch, fitment was absolutely perfect. very little prep work required, I primed and wet sanded once and they were ready for paint. they wrap around the tail lights, and come up to the door. notice how the lines ride the window and trunk lines perfect. they come with a nice gas door assembly, but im a ricer and i like how it looks sunk... overall I love them. -jsu1012
S14
s14
$306
Follow window/trunk/taillight lines, with a stepped side. In my opinion the fit it absolutely horrible. A ton of sanding and straightening has to be done so things line up how they should.
Last edited by StoopidLoose88; 04-11-2015 at 07:01 AM.. Reason: adding information
StoopidLoose88 is offline   Reply With Quote
Old 04-09-2015, 09:07 AM   #2
jsu1012
jsu1012's Avatar
jsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to behold
If you really did google and looked at the lines and styles of the overs, you'd have each down within 30 min. but i'll play along.
here's mine:
Brand: chargespeed , 50mm
s13 coupe
price:$659.00 shipped.
quality: top notch, fitment was absolutely perfect. very little prep work required, I primed and wet sanded once and they were ready for paint. they wrap around the tail lights, and come up to the door. notice how the lines ride the window and trunk lines perfect. they come with a nice gas door assembly, but im a ricer and i like how it looks sunk... overall I love them.
@streetstyle_jay
jsu1012 is offline   Reply With Quote
Old 04-09-2015, 05:48 PM   #3
StoopidLoose88
Thank you for contributing, car looks great, I actually follow you on Instagram already lol. How were your overs fastened? Most I've seen are riveted but yours almost look factory smooth.
Old 04-09-2015, 07:12 PM   #4
TurboTiger
TurboTiger is an unknown quantity at this point
here's mine:
s13 coupe
price:$659.00
Damn. It's refreshing to see a 240 as clean as your on these boards.
TurboTiger is offline   Reply With Quote
Old 04-09-2015, 07:33 PM   #5
DriftingBrandon
DriftingBrandon's Avatar
DriftingBrandon is an unknown quantity at this point
Maybe you guys can help me. I'll of course will measure and fine tune myself, but some insight is awesome. 1993 Nissan 240sx S13 (will 5 lug swap) I have Front: 17x10 +5 (215/45/R17) & Rear: 18x11 +25 (245/40/R18) . What spacer/overfender sizes would you think would be the best match. I want atleast 50mm rear fender, atleast 25mm front. Thanks!
DriftingBrandon is offline   Reply With Quote
Old 04-09-2015, 07:42 PM   #6
jsu1012
jsu1012's Avatar
Lol right on. Mine are pop riveted .
Thanks man.
Depends on how much camber you want to run. That front size would be too easy. I did 18x10.5 , -3 up front on metal fender. The rear depending on ride height and camber would be 12-20mm spacers .
@streetstyle_jay
Old 04-10-2015, 07:27 AM   #7
StoopidLoose88
Ok I updated the original post to start consolidating the information lol I hope to make this a pretty full guide for people looking into overfenders
Old 04-10-2015, 07:57 AM   #8
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
Here is mine, they are Extreme Dimensions "Gt-R" style 50MM, Which would be a copy of Origin Type 2.
Fitment was surprisingly good, they are thin and VERY flexible. Only Issues i have with them are:
this is just tape holding them on
I used Rivit Nuts to fasten them (low profile allen head screws)
Sorry i dont currently have any better pics of the back
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 04-10-2015, 08:21 AM   #9
xGhettosledx
xGhettosledx is an unknown quantity at this point
I have authentic origin type 2 50mm rears on my s14 and in my opinion the fit it absolutely horrible. A ton of sanding and straightening has to be done so things line up how they should.
xGhettosledx is offline   Reply With Quote
Old 04-11-2015, 06:22 AM   #10
henjupole
henjupole is an unknown quantity at this point
henjupole is offline   Reply With Quote
Old 04-11-2015, 06:30 AM   #11
StoopidLoose88
They look really good though, I'll add the info for these to the original post!
Congrats, you're the first s14 to post in this thread! Lol but that surprises me, previously I had never heard anything bad about origin products, but it has been noted and I'll post this in the original post, thanks!
Old 04-13-2015, 12:51 PM   #12
DennisC
DennisC's Avatar
DennisC is an unknown quantity at this point
Extreme Dimensions Duraflex M-1 Sport 30mm Rear over fenders for S14
Fitment-9/10
Fit very well once bolted on and I just had to fix a few very minor cracks. Required no trimming.
Only held on with tape
Primed and block sanded
Test fitted with only 8 screws
Painted and installed with 25 rivnuts/screws per side
DennisC is offline   Reply With Quote
Old 04-13-2015, 01:19 PM   #13
jsu1012
jsu1012's Avatar
when you need 25 rivets on each side i dont think its a 9/10 fitment lol. driver side in front of the wheel the panel is cut at an angle or what?
@streetstyle_jay
Old 04-13-2015, 01:24 PM   #14
bigs
bigs is a glorious beacon of lightbigs is a glorious beacon of lightbigs is a glorious beacon of lightbigs is a glorious beacon of lightbigs is a glorious beacon of lightbigs is a glorious beacon of lightbigs is a glorious beacon of lightbigs is a glorious beacon of lightbigs is a glorious beacon of lightbigs is a glorious beacon of lightbigs is a glorious beacon of light
Originally Posted by DennisC View Post
Fitment-9/10
Those look like they fit like absolute shit...
bigs is offline   Reply With Quote
Old 04-13-2015, 01:25 PM   #15
StatticMyke
StatticMyke's Avatar
StatticMyke is an unknown quantity at this point
Fitment-9/10
9/10 wtf???? Both sides have obvious differences in how they are cut. On the drivers side there is a gap in the front of the fender well. Whats up with the passenger side around the tail light? Looks like a kid cut it with some scissors.
StatticMyke is offline   Reply With Quote
Old 04-13-2015, 01:35 PM   #16
DennisC
DennisC's Avatar
It's extreme dimensions... wasn't expecting perfect looking parts. Maybe I gave it too high of a rating then if you guys really think it fits that bad. For the price I got them for and they fit right on out of the box, I think it was worth the money. The main reason I got them was to cover up my quarter panel bondo job by a previous owner.
25 is just about what every one else uses.
Old 04-13-2015, 03:22 PM   #17
Martino
Martino's Avatar
Martino is an unknown quantity at this point
More like 8 - 10 lol
IG: @vsMARTINO
Martino is offline   Reply With Quote
Old 04-14-2015, 04:17 AM   #18
BoostinIX
BoostinIX's Avatar
Trader Rating: (29)
BoostinIX is an unknown quantity at this point
Feedback Score: 29 reviews
Dmax are lookin spiffy for the price
BoostinIX is offline   Reply With Quote
Old 04-14-2015, 07:51 AM   #19
jsu1012
jsu1012's Avatar
lol na man . i used maybe 8-10.
@streetstyle_jay
Old 04-14-2015, 09:43 AM   #20
simmode1
simmode1's Avatar
Nevermind. Wrong thread.
"Simplicity is the key to brilliance." - Bruce Lee
Old 04-15-2015, 05:43 AM   #21
DriftingBrandon
s13 What size I've fenders?
Edited: repost
Old 04-15-2015, 07:15 AM   #22
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
get 50mm fenders^
Old 04-15-2015, 10:09 AM   #23
DriftingBrandon
s13
Originally Posted by blueshark123 View Post
get 50mm fenders^
I Think so too. The previous owner just told me he ran a 27mm (1.06) spacer with a 50mm fender and the fitment was perfect. My 1" spacer should be around the same. Shouldn't make a huge difference. I always have the option to tuck my 18's
Link to his pictures: http://zilvia.net/f/showthread.php?t=594403
Old 04-15-2015, 03:22 PM   #24
DriftingBrandon
I need Coilovers I'll run probably -5 camber. but what fenders should fit my car? 18x11 +25 with an 1" spacer. 30mm or 50mm?
Images are now Visable.
Old 04-15-2015, 09:10 PM   #25
DriftingBrandon
First photo is a 30mm over fender on the REAR placed on the side. I think 50mm rear is the idle size. OKAY. The front... front Wheels. 17x10 +5 with a 1" spacer. I think 30mm front will be perfect with some camber.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 04-15-2015, 09:48 PM   #26
Kuma
Kuma's Avatar
Kuma is an unknown quantity at this point
is the 1" spacer necessary? seems like if 50mm overs were perfect with 1" spacers, 30mm overs should be really close without 1" spacers... might have to run without camber, but I don't personally see that as a bad thing.
Kuma is offline   Reply With Quote
Old 04-15-2015, 10:15 PM   #27
MR_GUTTI
MR_GUTTI's Avatar
MR_GUTTI is an unknown quantity at this point
I agree with Kuma, maybe because I'm not a fan of the 50mm over! I will remove the spacer and use the 30mm
I have 18x10.5 +0 with no spacer and 30mm over ( I still need to add camber )
MR_GUTTI is offline   Reply With Quote
Old 04-15-2015, 10:35 PM   #28
DriftingBrandon
Nice, yes my goal is F: 30mm R: 50mm. I love the 50mm because when you look from the back. The wheel and tire is showing from the side, yet isn't poking out of the fender.
[IMG][/IMG]
Old 04-16-2015, 10:54 AM   #29
gallo
gallo's Avatar
gallo is an unknown quantity at this point
Vis 25mm front and rear. fit good no modification just rivet them right in
Corgis, R34 GTR, LS-14, S13 sil-40, LS-260z
IG=@gallo_915
gallo is offline   Reply With Quote
Old 04-16-2015, 11:39 AM   #30
DriftingBrandon
Do they make 30mm front s13(pop up) 180sx front fenders? 30mm would be perfect. I've been doing some searching and haven't found anything but 30mm rears.
How is VIS fitment? I could go 25mm with a ton of camber lol
comparison, guide, overfender, overfenders, s-chassis
