Old 04-16-2015, 11:57 AM   #31
Martino
Martino's Avatar
Martino is an unknown quantity at this point
Originally Posted by TopazBrandon View Post
Do they make 30mm front s13(pop up) 180sx front fenders? 30mm would be perfect. I've been doing some searching and haven't found anything but 30mm rears.
How is VIS fitment? I could go 25mm with a ton of camber lol
I have 25mm fronts as well and honestly I WANT that extra 5mm a 30 would give me lol.
IG: @vsMARTINO
Martino is offline   Reply With Quote
Old 04-16-2015, 02:47 PM   #32
DriftingBrandon
DriftingBrandon's Avatar
DriftingBrandon is an unknown quantity at this point
What are your specs / spacers
DriftingBrandon is offline   Reply With Quote
Old 04-17-2015, 04:35 AM   #33
DriftingBrandon
bump to the top
Old 04-17-2015, 04:10 PM   #34
DriftingBrandon
Bump to the top
Old 04-17-2015, 05:47 PM   #35
Martino
Martino's Avatar
18 x 9: effectively -3
IG: @vsMARTINO
Old 04-18-2015, 11:37 AM   #36
DriftingBrandon
I'' just get 20mm front and 50mm rear
Old 04-20-2015, 07:47 AM   #37
eastcoaststeeze
eastcoaststeeze is an unknown quantity at this point
Here is for the S14:
Front: Origin Lab (type 3) 45mm vented fenders
- fit nice and good quality, had to drill holes for mounting
Rear: Origin Lab (Type 3) 55mm overs
- horrible fitting, lots of sanding, wouldnt even sit right and when trying to mount you can see stress cracks forming. So I cut them up and had to mold them to the car as there was no other option
(disregard the zenki hood)
eastcoaststeeze is offline   Reply With Quote
Old 04-20-2015, 08:16 AM   #38
DriftingBrandon
Could have sent them back. I will if I get craps products.
Old 04-20-2015, 02:57 PM   #39
eastcoaststeeze
as much as I would have liked to, I didnt have time to as I was on a time crunch to get the car completed and to Sema, so i had to mold them to the car instead.
Old 04-20-2015, 03:53 PM   #40
StoopidLoose88
StoopidLoose88 is an unknown quantity at this point
Bummer that they didnt work out of the box but the final product looks great!
StoopidLoose88 is offline   Reply With Quote
Old 04-20-2015, 04:10 PM   #41
Bushido
Bushido's Avatar
rear quarters are the only area where molding is acceptable imo.
Old 04-20-2015, 08:45 PM   #42
Kuma
Kuma's Avatar
Kuma is an unknown quantity at this point
anyone have detailed pics of charge speed rears on s14? I was planning on going origin, but now I'm unsure... eastcoaststeeze pulled them off nicely, but if charge speed has better out of box fitment I'm sold.
Kuma is offline   Reply With Quote
Old 04-20-2015, 09:37 PM   #43
slutz4
slutz4 is an unknown quantity at this point
Chargespeeds fitment is virtually flawless. If I wasnt lazy Id upload some pics on here of my s14.
slutz4 is offline   Reply With Quote
Old 04-20-2015, 11:15 PM   #44
Renelovesnike
Renelovesnike's Avatar
Trader Rating: (30)
Renelovesnike is an unknown quantity at this point
Feedback Score: 30 reviews
@ KUMA
ChargeSpeed +50's on s14's fit flawlessly out the box!! could not be happy'er with an out of the box aftermarket product.
Renelovesnike is offline   Reply With Quote
Old 04-21-2015, 07:02 AM   #45
1Day
1Day's Avatar
1Day is an unknown quantity at this point
Here are a couple of mine at mock up stage, I think the skirt was the only thing holding them on.
Used these, rivnuts, to mount them for easy removal (9 per side)
Mounted
1Day is offline   Reply With Quote
Old 04-21-2015, 10:32 AM   #46
OBEEWON
OBEEWON's Avatar
Looks dope. Rivnuts are the way to go. What size did you use? I need to get some
Old 04-21-2015, 11:25 AM   #47
1Day
1Day's Avatar
M5? The part number is from Fastenal and I used SS button head bolts. I totally took the idea/part #, whole shebang, from a Modified Mag. article they did about putting overs on a time attack S2000. (March '10 was the issue)
Old 04-21-2015, 11:54 AM   #48
Kuma
Kuma's Avatar
Thanks 1day! Your car looks great.
Old 04-21-2015, 11:58 AM   #49
StoopidLoose88
Those look great, those are the 50mm charge speed ones, right? I'll add those to the OP later. May I ask why you decided to go with rivnuts over just rivets?
Old 04-21-2015, 02:24 PM   #50
1Day
1Day's Avatar
Thanks guys. Correct 50mm chargespeed's, I went with Rivnut mainly for cleaning. I get a lot of small stones behind them.
I'm so bummed about the quality of the origin type 3's. I was thinking about selling mine for those but IDK now.
Old 04-21-2015, 11:04 PM   #51
bataangpinoy
bataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymore
Originally Posted by xGhettosledx View Post
I have authentic origin type 2 50mm rears on my s14 and in my opinion the fit it absolutely horrible. A ton of sanding and straightening has to be done so things line up how they should.
+1
30mm Tatakadasi rears on my coupe, with 20mm silvia fenders for the front.. fitment is junk.
Fronts:
1) Front wheel arches are not even from side to side (caster is dead even)
2) Lots of air pockets/defects in the right front fender. I watched chucks of the fender fall off/chip away as i was fitting it to the car. I would drill, and the fender would chunk.
3) Driver front fender is also molded 'short' in relation to the hood, the gap is very large compared to the other side.
4) Couldn't get the fender to line up right with the bumper, i'll have to add material to the flange to be able to center the fender.
Rears:
Fitment with these is a bit better, but still lots of work required to get them on properly. This time, the pass. rear fender seems to be cut short, and warped? I'm guessing this is due to the provision for the gas flap. Driver side rear over fender went on much easier, but seems to have more flare than the pass. side.
Would not buy this crap again at 350 per pair, would rather buy the shitty ones from VIS if I have to work the fenders this much to get them to even come close to fitting.
Originally Posted by GTR-Garage
Handling, power and style must be in harmony.
bataangpinoy is offline   Reply With Quote
Old 04-30-2015, 03:23 PM   #52
livelovesole
livelovesole is an unknown quantity at this point
I've searched for this stuff already but not coming up with anything, but Can anyone upload a s13 hatch with chargespeed 50mm rear overs ? Cant find many. I got a decent sized dent on the body line of my hatch so i feel like the best way to fix it is overfenders. And if anyone can tell me how 18x10.5 fit with 50mm overs as well too that'd be great.
livelovesole is offline   Reply With Quote
Old 05-01-2015, 10:25 AM   #53
StatticMyke
StatticMyke's Avatar
StatticMyke is an unknown quantity at this point
FineLine Tuning 50MM
S13 Hatch
$299 before shipping. Think $350 shipped
Tatakidashi reps pretty much, or very similar.
Actually fit pretty damn well. A little bit of trimming but that's it really. I'd say 7/10 at minimum.
Don't really have any other close ups but I can get some if someone wants to see them.
StatticMyke is offline   Reply With Quote
Old 05-01-2015, 10:34 AM   #54
jefferz
jefferz's Avatar
jefferz is an unknown quantity at this point
I Did riv nuts for my overfenders we use all the time for other builds. they help with everything
File Type: jpg 10534065_733308240063912_6436153201927317711_n.jpg (43.6 KB, 172 views)
S13 Coupe, S14 Kouki
Crew Chief jeff Jones Racing
jefferz is offline   Reply With Quote
Old 05-01-2015, 12:06 PM   #55
DriftingBrandon
S13 Hatch
What size wheel, and spacers? Because I have a 18x11 (you have 18x9.5) I have 25mm spacer (idk about you) and it looks to be that my wheel still wont fit flush and will be tucked a little
Old 05-01-2015, 12:53 PM   #56
hellaslows13
hellaslows13's Avatar
Trader Rating: (28)
hellaslows13 will become famous soon enoughhellaslows13 will become famous soon enoughhellaslows13 will become famous soon enoughhellaslows13 will become famous soon enough
Feedback Score: 28 reviews
CHARGESPEED 50MM. PBM REAR DROP AND PBM LCA. 18x12 +7 -3.8 camber.
wavybert / zenki / build thread
hellaslows13 is offline   Reply With Quote
Old 05-01-2015, 12:56 PM   #57
StatticMyke
18x9.5 +15 with a 30mm spacer. Rear quarters were fu*ked is why I went with overs.
Old 05-01-2015, 02:09 PM   #58
gallo
gallo's Avatar
gallo is an unknown quantity at this point
30 up front would be great 25 is not to bad in the rear
Corgis, R34 GTR, LS-14, S13 sil-40, LS-260z
IG=@gallo_915
gallo is offline   Reply With Quote
Old 05-02-2015, 07:13 PM   #59
Cpreston
Cpreston's Avatar
Cpreston is an unknown quantity at this point
Anyone have any pictures or info about the gtp f kon-x s13 overfenders?
Cpreston is offline   Reply With Quote
Old 05-02-2015, 09:46 PM   #60
DriftingBrandon
[/IMG]
[IMG]
comparison, guide, overfender, overfenders, s-chassis
