Old 05-07-2015, 06:43 AM   #9
nddavis2
nddavis2 is an unknown quantity at this point
Thank you both very much for all the info. I actually think I would have been better off with starting the harness from scratch and not with a hack job of one however I will say the car would start and run fine on that harness. There are some relays wired into the lines right now which could be why they skipped out on the fuse box but I want to make sure. I have the harness 90% taken apart just don't have the portion closest to the ecu plug so i haven't broken it down wire to wire yet. Have all info for the harnesses printed out so I'm good to go on those parts. I'll lay it out and figure out what to connect where before I start hacking away.
Oh and yes the throttle body works just fine.
nddavis2 is offline   Reply With Quote
