06-25-2015, 09:03 AM | #1 |
Trader Rating: (29)
Feedback Score: 29 reviews
Enjuku Racing- *In Stock* Duel Rear Caliper Kit
Dual Rear Caliper Kits Now In Stock!
MAVERICK MOTORSPORTS DUAL REAR CALIPER KIT - NISSAN 240SX S13/S14 89-98 So what exactly is it? This bracket allows you to use 2 pairs of Z32 rear calipers for AWESOME stopping power. One pair of calipers gets plumbed up like normal and works off of the brake pedal. The other pair gets plumbed SEPARATELY to the hydraulic handbrake. No more weird pedal feel when pulling the e-brake and the footbrake! You now have a dedicated setup for the hydraulic handbrake. Please Note: This will ONLY work with 5 lug hubs What comes with the kit: - One left bracket - One right braket - 2 hub rings to align rotors correctly. - 8x M12 Class 10.9 Bolts for hub. - 8x M12 Split locking washers. - 8x M10 Class 10.9 Flange head bolts for calipers. - 8x M10 Stainless steel flat washers. Features: - Made in the USA by an Aerospace/Medical certified machine shop with ISO9001:2008 certs. - 6061-T6 aluminum for strength and low weight used on brackets and hub rings. - The brackets are CNC'd and not water jetted. CNC is much more precise and cleaner. - Hardened steel liners(Rc 62-64) - FEA tested as well as real world tested on track. - Huge 11.7" rotors on the rear. Need to know: - You will use REAR rotors from one of the following vehicles. Code: FORD MUSTANG BULLITT 2001 FORD MUSTANG COBRA (1994 - 2004) FORD MUSTANG COBRA R 1995 FORD MUSTANG COBRA SVT 1995 FORD MUSTANG SVT COBRA R 2000 - You will need to cut off the OEM brake mounts on the upright. - Aluminum uprights(Z32, R32, etc) need to have a few places ground down. Quick work with a grinder. - This will space your wheels out 8mm. It's like adding an 8mm spacer to the wheels. Please keep this in mind if you have flush fitting wheel already. - We recommend using a 3/4" bore hydraulic handbrake. 5/8" will work as well. - Allows the proper use of a hydraulic handbrake. No more rigged inline setups that don't work when you need them to!
Office: 352-241-8399 / 1-888-SR20DET (772-0338) YouTube.com/c/EnjukuRacingParts http://www.enjukuracing.com [email protected] Last edited by Enjuku Racing; 07-01-2015 at 02:42 PM.. |
06-25-2015, 10:55 AM | #3 |
Trader Rating: (130)
Feedback Score: 130 reviews
very cool product. I like all the things I've seen from maverick.
I'm not trying to steal your thunder, but its listed for only $220 on the maverick website. http://www.maverick-motorsports.com/...aliper-bracket |
06-29-2015, 06:31 PM | #5 |
Will the 300ZX parking brake still work with this?
Do you need; Right side (USDM Passenger side) Replica S13 OEM Silvia Aero Bumper Grill S13 Silvia J's, Q's, K's, A's Bumper grill inserts. Male Plugs for S15 headlights PM me if you need them. |
06-30-2015, 02:56 PM | #6 | |
Trader Rating: (29)
Office: 352-241-8399 / 1-888-SR20DET (772-0338) YouTube.com/c/EnjukuRacingParts http://www.enjukuracing.com [email protected] |
06-30-2015, 02:56 PM | #7 |
Trader Rating: (29)
Good Afternoon,
The rear factory braking system for the 300zx will not work with with this kit.
06-30-2015, 02:57 PM | #8 |
Trader Rating: (29)
07-01-2015, 08:48 AM | #10 |
Trader Rating: (29)
With this kit you will lose the factory parking brake function and replacing it with a hydro braking system. This modification is only recommended for racing applications.
07-01-2015, 02:43 PM | #12 |
Trader Rating: (29)
