07-28-2015, 04:22 PM | #1 |
**WSRD Brake Line Relocation Kits!**
Our brake line relocation kits route under the factory crossmember, cleaning up the bay and making room for turbo setups. They're compatible with S13/Z31/Z32/Pathfinder master cylinders and are made in the USA! Teflon braided stainless line coated in a protective teflon outer shell means these are built to last! (Pictured with V1 High pressure power steering line). Comes with all the fittings to connect your master cylinder to the caliper and rear brake line(s). http://www.whalentuned.com/nissan-240sx.html Zilvia price: $199 shipped! PM me to order!
Build: http://zilvia.net/f/showthread.php?t=643065 Friends don't let friends buy knock-offs. Last edited by PoorMans180SX; 07-29-2015 at 06:13 AM.. |
07-28-2015, 05:14 PM | #3 |
We don't currently offer the caliper lines, but we recommend and install Goodridge lines here at the shop on a variety of vehicles. We can get them both to you in the same box.
07-29-2015, 10:36 AM | #5 |
HAHA, they are made to order, but the maximum turn around time is four weeks. We usually get them done in two.
07-30-2015, 12:56 AM | #8 |
installed my kit finally, went in fantastic! more than enough line and everything went together smoothly. kit is easy to figure out. would support Whalen again!!!
07-30-2015, 08:24 AM | #9 | ||
You have a PM good sir.
Thanks for the kind words! Good to hear!
08-07-2015, 03:11 PM | #11 |
Is the fitting with the o-ring seal that goes into the high pressure side of the rack an off the shelf item or is it custom made? I've read that the off the shelf fittings do not correctly seal because they are slightly short and what people have done is machine it to get the o-ring to fit correctly.
08-10-2015, 10:24 AM | #12 | |
I only have after shots unfortunately!
08-11-2015, 01:01 PM | #14 |
This kit won't work with a S14 master. If you were local, we could make you a kit, but I don't feel comfortable building a kit without the ability to test fit it. I've been trying to get a S14 in here for a while now, but so far haven't been able to. When we do, we'll build a kit and post it up!
