z32/s13/s14/sr20/2jz/mkiv
trying to clean out my garage and so i can afford to get my tune done asap!! list of stuff is all obo and please only pm me.
-2jz factory upper and lower intake manifold. $100 -2jz factory oil cooler assembly $25 -2jzgte vipec v88 ecu (specific to a mkiv ecu housing) $1600 -2jzgte single turbo,twin scroll, manifold. ebay but supported. $120 -2jzgte rps single plate clutch. was told good to 800rwhp? $400. -2jzgte valve covers. painted purple but has paint chips. $120 -2jzgte factory cam gears $40 -2jzgte 1000cc precision injectors. low impedance $200. recommend flow test/cleaning -2jzgte 850cc siemens injectors. low impedance. only used for startup. $300 -s14 sr20det longblock. needs to be sleeved and the head needs machining. will have intake manifolds and whatever else on them. no exhaust manifolds. $150 -s14 sr20det longblock. engine needs to be honed and decked but salvageable. #2 injector failed and lost compression. head was freshly machined. cleaned. and vac tested and bc springs and retainers and new valve stem seals. $800 for head and block. block is disassembled at the moment though. -sr20det spec stage 3 clutch and steel flywheel. worked awesome! $400 -sr20det 5 speed transmissions. freshly gone over and resealed. $250 each. have 2 -ka24de complete engine. needs a harness though. ran awesome when pulled from car. comes with ecu.$350 -rs enthalpy tuned ecu. 18psi on husky 94 on a s15 t28 turbo. $150 -s15 t28 turbo. bought brand new from enjuku. ran 18psi all season. tiny bit of shaft play but still a awesome working turbo $550 with lines and restrictor -s14 sr20det wiring specialties harness into a 91 240sx with the white interior plug. $250 -sr20det wiring specialties trans/starter/alt harness bnib. $150 -sr20det wiring specialties trans/starter/alt harness, used has oil on it. $75 -five-0 motorsports 550cc injectors. #2 might have an issue. recommend flow testing/cleaning. $150 for all 4 -s13/14 sr20det jwt 260 camshafts. mild use. has some scoring but work perfectly. $500 -s14 sr20det valve covers. have 2. one is oem black. the other is painted green.$80 each -sr20det os gikken twin plate str clutch. haven't measured for wear. $600 -aeromotive 340lph fuel pump. was used for startup. $120 -walbro 255lph fuel pump. have 2. both used but still good. were used for testing. $70 each -1990 nissan 300zx 2+2 na, lhd, rebuilt status on car but is straight and minimal to zero rust. manual, shell with full black leather interior,red exterior. NOT PARTING. no front brakes. $1000 i may add more to this as I'm probably forgetting parts. prices are obo. NO SEPERATING PARTS. please pm with serious inquiries. thanks. ALL PRICES ARE CANADIAN$$$$. located in edmonton, alberta, canada. can email pics. |
