Old 11-08-2004, 02:06 PM   #1
Thrill Capsule
Thrill Capsule's Avatar
Thrill Capsule is an unknown quantity at this point
Send a message via AIM to Thrill Capsule
KA car doesnt return to idle right away
I just finished swaping a lower mileage KA and M/T last week. Everything is up and running perfect. Except when say at a stop light the motor doesnt drop back down into idle. instead it revs at about 1700 rpm for 5-10 secs then goes down to Idle.
My EGR is half disconnected but i totally removed it and put a resistor in the line today and it made no difference.
The motor i swaped was a M/T and im still using the A/T harness and ECU. So there are 2 plugs that are supposed to go the TPS, but the M/T only has one. Could this be the reason?
Any opinions or other thoughts?
Thrill Capsule is offline   Reply With Quote
Old 11-08-2004, 03:00 PM   #2
mjjstang
mjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to behold
Send a message via AIM to mjjstang
well im not sure at all, but are you sure your throttle cable is working correctly, like its not sticking a bit. worth a shot, should take 30 seconds to check.
mjjstang is offline   Reply With Quote
Old 11-08-2004, 04:48 PM   #3
joewantstodrift
joewantstodrift's Avatar
joewantstodrift is on the path to ruinjoewantstodrift is on the path to ruin
Send a message via AIM to joewantstodrift
im having the same problem with my sr. everyone says its a vacuum leak. i have to check it out in the next few days.
joewantstodrift is offline   Reply With Quote
Old 11-10-2004, 12:28 PM   #4
Thrill Capsule
Checked throttle cable and cleaned the throttle body and it is still doing the same thing. Any other suggestions?
Old 11-10-2004, 01:47 PM   #5
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
I have the same problem, and i cleaned the throttle body, cleaned aiv, cleaned iavc, and still no luck. But i do have a egr code and detonation code. from what i heard, if you block the egr tube on the exhuast side with a nickel or however you want, you can get ride of the problem.
Old 11-10-2004, 09:27 PM   #6
Thrill Capsule
Yeah ive got the exhaust mani welded shut. Im hesitant on deletingthe whole system though, Im gonna hook it back up once i get a header.
Anyway sometime this week or next ill put the old A/T tps sensor on and see if that clears this up. It is very annoying
Oh yeah thanks for reminding me, im gonna check for codes. No CEL as of now, but it doesnt hurt to look.
Old 11-10-2004, 09:59 PM   #7
stillmatic
stillmatic's Avatar
stillmatic is on a distinguished road
The problem is the AUTO ecu. Swap it with a manual. Have you been having cold start problems as well?
stillmatic is offline   Reply With Quote
Old 11-11-2004, 09:23 PM   #8
Thrill Capsule
No cold start issues at all, but i will put the M/T ecu in then. See if that clears it up.
Old 11-15-2004, 02:08 PM   #9
Thrill Capsule
The M/T ecu has cleared everything up. Thank you stillmatic.
