![]() Join Date: Jul 2001
dont use the dampner.... just bypass it. makes it much easier to bleed.
www.enjukuracing.com |
#2 | |
You'll also need a hole saw to cut a hole in the firewall for the CMC. The center console on the front clip is angled wrong. Reuse the LHD one. GL, Todd 93 Coupe 90 Coupe |
you can use to sohc ps lines, they do require bending to the other side, but the main problem i had was the banjo bolt...the sohc hole on the line was too small for the sr ps bolt to fit thru, AND the sohc bolt was also too small for the sr ps pump...so...i had to enlarge the sohc hole on the line for the sr ps bolt to fit into and screw into the sr ps pump...i probably didn't make any sense...pm me for details if you want...
![]() Join Date: Aug 2004
![]() Hey Luke, glad your not going to serve time. Anyways, sr20store.com told me that the brake pedals from the front clip won't fit. Thanks for the help. I guess if worse comes to worse, i can just order the clip and order parts later if I find out things dont work. Only problem with that is that I have more downtime and I only have about 3 weeks at the most to do it.
