sorry if it was confusing, but what i meant was pull out the spark plug wires to see if one of the fuel injectors might be bad (this only works if you KNOW that the plugs and wires are good)...another thing you can do is fill up with the highest octane and then put some fuel injector cleaner cleaner in the tank, and see if it goes away (this is only a temporary fix and will just help in diagnosing the problem)
fuel injectors are pretty easy, just unplug the harness and undo all the bolts/ screws that hold them in there...
IMG exceeds forum limit of 150kb
Originally Posted by Var
I'd rather take the bus with a bus-full of AIDS infected naked rape convicts than drive a VW.
