Old 11-17-2004, 11:55 AM   #1
nd240sx3
nd240sx3's Avatar
nd240sx3 is a well-known jackass
Send a message via AIM to nd240sx3
rear lights 2 go out when u hit brake whats up?
ok well i just bought 89 coupe. when the parkin lights are on all rear lights are lit. but when u hit brake the last one on left and inner one on right go out, for some reason. anyone have an idea what it could be. cause car wont pass inspection like that and i need it fixed now
nd240sx3 is offline   Reply With Quote
Old 11-17-2004, 11:58 AM   #2
s13driver
s13driver is an unknown quantity at this point
check the bulbs ? if they are bad then replaces the bulbs ?
it is so hard to educate the uneducated.
s13driver is offline   Reply With Quote
Old 11-17-2004, 11:58 AM   #3
Ritz S14
Ritz S14's Avatar
Check your tail light ground. On toyotas, the ground is scewed onto the taillight with another ground to chasis. Pretty common for toyotas.
Ritz S14 is offline   Reply With Quote
Old 11-17-2004, 12:07 PM   #4
s14 blacktop
s14 blacktop is an unknown quantity at this point
Send a message via AIM to s14 blacktop Send a message via MSN to s14 blacktop Send a message via Yahoo to s14 blacktop
You might have a couple of shorts in your wires..
check all your fuses and relays...
s14 blacktop is offline   Reply With Quote
Old 11-17-2004, 12:29 PM   #5
nd240sx3
nd240sx3's Avatar
checked fuses and replaced bulbs
well i checked all fuses and relays and replaced all bulbs and still nuttin but havent checked grounds yet they looked good so i didnt mess with them
Old 11-17-2004, 01:54 PM   #6
nd240sx3
nd240sx3's Avatar
Fixed The Prob
ok well it was the grounds on the bulbs 2 had melted and plastic got in between the screw and tab so thanx for everyones help
Old 11-17-2004, 01:55 PM   #7
Ritz S14
Ritz S14's Avatar
Haha YES I was right.
You're welcome!
