Old 06-15-2009, 04:07 PM   #1
Blk240racer
Blk240racer's Avatar
Blk240racer will become famous soon enoughBlk240racer will become famous soon enoughBlk240racer will become famous soon enoughBlk240racer will become famous soon enough
Send a message via AIM to Blk240racer
transmission vibration after installing new clutch
its a '92 240, ka engine, originally a manual, installed a stage 1 clutch from exedy and fidanza flywheel. have a vibration in every gear, but its only noticeable in decel around 2500 down to 2000 rpm in 3rd and really bad in 4th/ it sounds like its coming from the diff but i think its just traveling through the whole powertrain. the driveshaft is in phase, i measured runout. i had the car up on a lift doing 10 mph and the tail shaft of the trans was wagging around so i thought it was the trans mount. i stuck a pole jack underneath it to take the weight of the trans off the mount and i could feel the vibration coming down the pole jack. i have a feeling that its the flywheel, maybe for some reason it wasnt balanced right or something else. Is anyone else having this problem and actually fixed it? i saw a few with no conclusion.
white '92 hatch
Blk240racer is offline   Reply With Quote
Old 06-15-2009, 04:16 PM   #2
HPKMotorsports3
HPKMotorsports3's Avatar
HPKMotorsports3 is an unknown quantity at this point
you bought that off ebay didnt you?
HPKMotorsports3 is offline   Reply With Quote
Old 06-15-2009, 04:19 PM   #3
Blk240racer
no, i heard from some people tell me it was a good choice for street ability. i bought the flywheel off amazon and the clutch kit from 240sxmotoring
white '92 hatch
Old 06-16-2009, 08:20 PM   #4
boosted armo
boosted armo is an unknown quantity at this point
maybe not all the flywheel bolts were torqued equally? or maybe warped flywheel?
boosted armo is offline   Reply With Quote
Old 06-16-2009, 09:07 PM   #5
Blk240racer
i torqued the bolts to spec and i used loctite. its possible that they came loose but i would think there would be some kind of clutch chatter or something though if the flywheel were loose, and it better not be warped already, theres like 200 miles on it or so since i did the job. im going to take a shot at the driveshaft. it didnt seem like the joint was shot and it was put back together right with the paint markings i made, but id like to upgrade to a one piece anyway, but id rather be putting my hard-earned bucks in the engine instead haha, oh well. ive researched some other sites and some people say the heavier duty clutch is hitting the natural frequency of the differenial, or "harmonic ressonance" Does anyone have anything to say about that or have the same problem? if its not hurting anything i dont mind driving it the way it is, its not like its an expensive car and has to be quiet. But if its slowly wearing my trans and diff out because its out of balance then ill be pissed.
white '92 hatch
Old 07-27-2010, 03:00 PM   #6
boggiewan
boggiewan is an unknown quantity at this point
i have this exact same issue; did you ever end up finding out what was wrong?
boggiewan is offline   Reply With Quote
Old 12-14-2015, 08:20 AM   #7
Drift_86
Drift_86's Avatar
Trader Rating: (60)
Feedback Score: 60 reviews
I'm having the same problem can anyone have more info on this problem. Could this problem be from wrong type of gear oil?
Old 12-17-2015, 03:09 PM   #8
Mitsubayati
Trader Rating: (18)
Mitsubayati is an unknown quantity at this point
Feedback Score: 18 reviews
Send a message via AIM to Mitsubayati
Did you change the TOB and pilot bushing with new replacements?
http://www.fittedlife.com/images/nickbanner.jpg
Mitsubayati is offline   Reply With Quote
