Motorsports and Skilled Driving Discussion for Organized Racing and motorsports and tips and techniques at becoming a better driver. |
03-21-2014, 04:10 PM | #1684 |
I recently started drifting my E93 m3
and found my main trouble is when for example I enter in 2nd with a feint(drifting to the left) and when I finish the long drift I need to slow and transition into a slower left then swoop right.. that slowdown, into the 2nd turn, maintaining drift is hard for me. I have the power, but my seems to want to keep following the long/fast drift trajectory... From what I read so far e-brake is preffered for something like this? what technique could I use to slow and make that second turn better? e-brake? clutch kick?
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap. |
03-21-2014, 04:28 PM | #1686 |
Yea, I drove both mine and my girls cars.
mine was on stock susp. hers had coils, when i switched to hers it helped a lot.. then i got back in mine and did decent the rest of the day.
03-21-2014, 09:03 PM | #1687 | |
Brake towards the end of the long drift then use the eBrake for the switch/transition for the slower turn and clutch kick to gets the traction broken again if your too far down in the power band.
Vids of said turn/runs?
* PigNose SMIC Grille/Vent P# 62697-44F00 * LMK What you guys got |
05-05-2014, 09:39 PM | #1689 |
What kind of diff does the M3 have? If its a helical diff, that might be your issue. By design, it applies more torque to the wheel with more load, which is the outside wheel during a drift, and this naturally wants to make the car straighten out.
06-04-2015, 07:05 AM | #1690 |
Trader Rating: (48)
Feedback Score: 48 reviews
down hill drifting...
So I am not new to drifting and have had several setups. Most of are 220-300whp with a good neutral feeling and proper ride height, real lsd, and a 4.6 final drive. I am comfortable dry or wet(favor wet, easier on car and saves tires. Plus I live in the seattle area). I do most of my drifting at PARC, Evergreen, PGP, Pacific Raceways,and on/off ramps. My latest venture is down hill. Steep not just on ramps, but steep like you need to know what your doing. I am curious to know some of your feelings and preferences. I know ALOT of it is mental and commitment. But once you initiate(ebrake) do you let gravity take over(lets say its wet) ? Do you use throttle ? foot brake and ebrake ? Or is it just seat time and being familiar where your driving ? I am aware there is no single answer.I just want to hear some of your thoughts.
Do you suffer from vaginal dryness... |
12-18-2015, 03:50 PM | #1691 |
As far as entrances go, why do most drifters over here stick with handbrake entries? I understand if you're going for high speed entries in competition but I'm used to seeing drifters in Australia use Scandinavian flicks and mostly use the handbrake for correcting lines or extending your drift more angle, not so much as a means of entry/initiation.
Sent from my SM-G900V using Tapatalk |
12-20-2015, 05:49 PM | #1693 | |
12-23-2015, 11:53 AM | #1696 | |
Gravity will keep you sliding initially but you still need to follow through. Also, yes, mental as well. I found myself straying wide most of the time I messed up. Just look through the corner like riding a motorcycle and you should be fine.
12-30-2015, 10:35 AM | #1697 | |
Since I was in the middle of a transistion, the inertia and eventual pull of the downhill gravity gave me enough speed to slide through it without mashing the accelerator. But yea after you need to get on it to stay sideways. stock ka btw |
03-30-2016, 04:38 AM | #1698 | |
Trader Rating: (48)
