Old 01-26-2016, 07:36 PM   #1501
alwaysnboost
alwaysnboost's Avatar
alwaysnboost is an unknown quantity at this point
In the process of ordering a set of welds for my s14. Looking to do a set of 28x10.5 15 inch rim(rear) and 17 inch runner upfront. Curious to know what offset or backspacing is best. Does anyone have a picture or a DRAG wheel on a 4.5 backspacing
alwaysnboost is offline   Reply With Quote
Old 01-26-2016, 07:48 PM   #1502
turbo-2ns
turbo-2ns is an unknown quantity at this point
8in is way to small for a 28.10.5
4.5in spacer?
turbo-2ns is offline   Reply With Quote
Old 01-26-2016, 07:53 PM   #1503
alwaysnboost
4.5in spacer?
Corrected. See above
Old 01-26-2016, 08:14 PM   #1504
turbo-2ns
Well than IMO 8in is way to small for a 28.10.5, and 4.5in of spacer is way to much , why would you ned this much spacer. Buy correct backspace or something close and use a small spacer
Old 01-29-2016, 07:30 PM   #1505
alwaysnboost
Just spoke with a very nice rep from Jegs and a fellow s13 owner himself! Here is what we came up with.
Weld alumi stars up front 17X4.5 with a 2 inch backspacing 26 inch tall upfront
Weld alumi stars out back 15x9 with 5.0 backspacing. a 27X10.5 tire most likely Mickey Thompson dot. Mind you I make 4xx to the tire and its a 95.
Old 01-29-2016, 07:32 PM   #1506
Tom N
Tom N is an unknown quantity at this point
No need for that much tire with 4xx hp.
98 240sx w/ S15 SR20DET, T2 20g, 11.22 @ 124.98
Tom N is offline   Reply With Quote
Old 01-29-2016, 07:52 PM   #1507
Sforteen
Sforteen is an unknown quantity at this point
5inch backspace isnt enough for a 15x9 you need at least a 6 inch
6.75 to 7 inch BS is about perfect for a 9 inch wheel
Sforteen is offline   Reply With Quote
Old 01-29-2016, 09:02 PM   #1508
Tom N
I use 5.5in BS on a 15x8 and they fit perfectly.
Not sure if you can really tell in this picture.
Old 01-29-2016, 10:08 PM   #1509
turbo-2ns
15×9 with a 5in bs will stick out, need 6.5
Old 01-30-2016, 05:21 AM   #1510
alwaysnboost
On the motor you're correct, but I plan on adding some boost this season
Old 01-30-2016, 04:10 PM   #1511
Sforteen
He said 15x9 a whole inch wider...
Not to mention your fenders are pulled alot...
Old 01-30-2016, 04:40 PM   #1512
Tom N
I'm Well aware he said 9in. I'm just saying what fit nicely as a 8in wheel. If one can do math they can figure the BS they will need for a 9in wheel.
Old 01-31-2016, 06:20 PM   #1513
black05srt-4
black05srt-4 is an unknown quantity at this point
Getting ready to swap the q45 differential into my s13 and wanted to see if you guys that are running those are leaving them stock or shimming them? Was going to just leave it stock. Car will be putting down 600ish whp hopefully.
1991 240 5.3l 4l80e, s366 turbo in the works.
black05srt-4 is offline   Reply With Quote
Old 01-31-2016, 06:37 PM   #1514
turbo-2ns
Q45 uses a sealed lsd, to my knowledge it can't be shimmed
Old 02-07-2016, 11:51 AM   #1515
ehhhregartless
ehhhregartless is making a name for him/her selfehhhregartless is making a name for him/her self
www.zeedakay.com
IG: @zeedakay
ehhhregartless is offline   Reply With Quote
Old 02-18-2016, 06:54 PM   #1516
1988montecarloss
1988montecarloss's Avatar
Trader Rating: (24)
1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute
Feedback Score: 24 reviews
any guys running really low cars with a 22-23" slick on the back?
IG: @Haley72692
1988montecarloss is offline   Reply With Quote
Old 02-18-2016, 07:15 PM   #1517
turbo-2ns
Way way too small, we use them on all motor Hondas up to about 300whp then move up to a 24.5 above that.
Old 02-19-2016, 02:46 PM   #1518
1988montecarloss
Trader Rating: (24)
my car is only around 300whp, id have to raise it to run 24.5"
IG: @Haley72692
Old 02-19-2016, 05:05 PM   #1519
blue88coupe
blue88coupe is an unknown quantity at this point
pretty low car, 26" ET drag slick on a 15x10x6.5 wheel
blue88coupe is offline   Reply With Quote
Old 02-19-2016, 05:44 PM   #1520
jr_ss
So determine what your priorities are, either drag the car's balls in the dirt or run a useable suspension setup capable of transmitting power to the ground. In other words raise it, it doesn't handle worth a damn THAT low anyway. You can't have your cake and eat it too.
Old 02-20-2016, 05:32 PM   #1521
1988montecarloss
Trader Rating: (24)
Low street/drift car is the main priority with my s chassis, was just curious if anyone had run a tire that small on a strip as I might mess aroud with some local 1/8 mile stuff this summer, If I can find some 22/23" slicks cheap enough I will try it, can't do any worse than my 205/50 will
IG: @Haley72692
Old 02-20-2016, 09:05 PM   #1522
zurud
zurud is an unknown quantity at this point
My friend run 22" slick on his s13. He got 1.7 60 foot and 7.8 in 1/8 mile. I think 22" n is not bad if you really want to use it
zurud is offline   Reply With Quote
Old 02-21-2016, 12:49 AM   #1523
1988montecarloss
Trader Rating: (24)
This is what I was lookin for, if I could pull a 1.6-1.7 60' at my local track I'd be content with that, that's a lot better than my 205/50 will get me
IG: @Haley72692
Old 03-10-2016, 08:45 PM   #1524
alwaysnboost
May I ask what your rear tire specs are in this pic?
Old 03-10-2016, 09:00 PM   #1525
Tom N
Mickey Thompson 26x10.5x15 ET Street's
Old 03-22-2016, 02:14 AM   #1526
Stumped
Stumped is an unknown quantity at this point
What kind of rear camber are you guys running? I'm running a 27x10.5x15 hoosier on a 10 inch wheel with about 750 rwhp. Just looking for a good starting point
Stumped is offline   Reply With Quote
Old 03-22-2016, 05:05 AM   #1527
jr_ss
If it's a drag only car, you'll want positive static camber. When you squat, you'll dip in to the negatives. I'd start at +.5 and sdjust from there.
Old 03-22-2016, 05:27 AM   #1528
Stumped
I'll be adding a racepak later on and can use shock travel sensors to get a good idea how much the car is squating when it spins and set the camber to zero at that height but thats a few months down the road.
Old 07-17-2016, 11:38 AM   #1529
Sforteen
Finally Ripped off a Decent pass!!
Heavy 3300ish w/me S14 Kouki RB25 on E85 24psi
10.14 @ 141.2 MPH 1.57 60ft
Old 07-17-2016, 11:41 AM   #1530
alwaysnboost
Nice work. At that mph you're sure to be in the nines. Are you spinning in second?
