Old 03-23-2016, 09:37 AM   #3541
c.f.169
c.f.169 is an unknown quantity at this point
Originally Posted by silviaks2nr View Post
295 clears rear fenders with a +30 offset on s14 with just a slight pull. 5mm is not a big difference.
I'm not looking to do a pull at this time, hence why I only have a 245 tire I want to put on. Just looking to see if it will stay within the 1/4 panel arch.
c.f.169 is offline   Reply With Quote
Old 03-23-2016, 10:10 AM   #3542
[240sx]
[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute
Originally Posted by c.f.169 View Post
I can appreciate your opinion, however I think you've mistaken what I mean by looks terrible. What I was trying to get accross was, I don't want it to stick past the 1/4 panel arch.
I understood what you meant. I was just exaggerated the point that this thread is more concern with MAX rubber > sacrificeing rubber for fitment.
Suggestion are going to be along the lines of "keep the 275s and ..."
-Pull the fenders
-add overs
-add flares
Or Camber.
I have the same wheels specs as you and my solution is 255s with some camber. Which Disqualified me from the thread.
[240sx] is offline   Reply With Quote
Old 03-23-2016, 12:28 PM   #3543
c.f.169
-Pull the fenders
-add overs
-add flares
Or Camber.
Thanks dude. I once again, appreciate the honesty.
Old 03-23-2016, 01:56 PM   #3544
s14hunter
s14hunter is an unknown quantity at this point
XXR 531 platinum wheels
Nitto 555 fronts and 555R rear tires
Front: 17x8 +25 with 235/45
Rear: 17x9 +35 with 275/40
Front and rear fenders rolled, zero pull.
Getting the LS treatment currently:
s14hunter is offline   Reply With Quote
Old 03-24-2016, 08:43 AM   #3545
Black R
Black R's Avatar
Black R is an unknown quantity at this point
Here's my solution for 335/30/18 on 18x12 et+20:
Cut and welded arches to be covered by 50mm overs.
S13 XE coupe: Aristo GTE, R154, GT37, Defsport Wilwood kit, KTS coilovers
Black R is offline   Reply With Quote
Old 03-24-2016, 11:17 AM   #3546
inuyasha3466
inuyasha3466's Avatar
inuyasha3466 is an unknown quantity at this point
That'll do it. I had 275/35 on 18x10.5-8 with 50mm fenders and about -1.5 degrees camber.
inuyasha3466 is offline   Reply With Quote
Old 03-29-2016, 09:20 AM   #3547
s14hunter
Currently getting the LS/T56 treatment
Old 03-29-2016, 09:24 AM   #3548
laextreme5
laextreme5's Avatar
laextreme5 is an unknown quantity at this point
Still LOTS of work to be done, still waiting on wheels to come back from being machined and lips made. Mocked up the tire for now. 335/30/18 r888 all around.
IMG_1982 by lawrx, on Flickr
IMG_1975 by lawrx, on Flickr
IMG_1972 by lawrx, on Flickr
My S13 Build
http://zilvia.net/f/showthread.php?p=6005967#post6005967
laextreme5 is offline   Reply With Quote
Old 03-29-2016, 09:48 AM   #3549
s14hunter
Another XXR setup
S14
kSport coilovers
XXR 531 Platinum wheels
17x8 et25 (front)
17x9 et35 (rear)
Nitto 555 front and 555R rear tires
235/45r17
275/40r17
Front and rear fenders rolled, zero pull. Alignment hasn't been done yet.
Old 03-29-2016, 10:50 AM   #3550
TarmacJunkie53
TarmacJunkie53 is an unknown quantity at this point
Just mocked up the rear wheels. Couldn't really get a good idea because the hub pitch for the hubs I got were 3mm too thick. Waiting on some spacers to clear the hub lip. Also the fronts with ctsv brakes.
Stance coilovers
Gktech control arms
Dmax front knuckles
Front rpf1 17x9 255/40/17
Rear rpf1 17x10e18 275/40
Sent from my VS990 using Tapatalk
TarmacJunkie53 is offline   Reply With Quote
Old 04-01-2016, 10:16 AM   #3551
Black R
Black R's Avatar
Wait, is that flares on overs?
Got any more pics?
Old 04-01-2016, 10:49 AM   #3552
laextreme5
laextreme5's Avatar
My build thread with all the details and more pictures can be found in my signature.
IMG_1984 by lawrx, on Flickr
IMG_1978 by lawrx, on Flickr
IMG_1974 by lawrx, on Flickr
My S13 Build
Old 04-01-2016, 11:29 AM   #3553
ka-titties
ka-titties is an unknown quantity at this point
wtf is with that caddy...
ka-titties is offline   Reply With Quote
Old 04-01-2016, 11:46 AM   #3554
laextreme5
laextreme5's Avatar
Friend of mines im doing some work to.
My S13 Build
Old 04-01-2016, 01:42 PM   #3555
LoSt180
LoSt180's Avatar
Trader Rating: (18)
LoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond repute
Feedback Score: 18 reviews
That's insane!
I have signatures disabled, so a direct link would be nice.
LoSt180 is offline   Reply With Quote
Old 04-01-2016, 02:01 PM   #3556
laextreme5
laextreme5's Avatar
http://zilvia.net/f/showthread.php?t=622223
My S13 Build
Old 04-11-2016, 09:54 AM   #3557
BoostyMcZface
BoostyMcZface's Avatar
BoostyMcZface is an unknown quantity at this point
Originally Posted by s14hunter View Post
S14
kSport coilovers
17x8 et25 (front)
17x9 et35 (rear)
235/45r17
275/40r17
any pictures sitting on the ground? looks like it fits really well.
BoostyMcZface is offline   Reply With Quote
Old 04-11-2016, 10:29 AM   #3558
Black R
Black R's Avatar
I finally got around to mounting my overfenders and wheel / tire combo:
335/30/18's tucked on 18x12 et+20 with a 7mm spacer (to simulate how they'll sit when I put the s14 rear subframe in).
I have 2 deg negative camber, but would like to have a bit less.
This is as low as the KTS coilovers will go in the rear.
These are 50mm overfenders, bowed a bit.
Old 04-11-2016, 12:21 PM   #3559
SoundEfx
SoundEfx's Avatar
SoundEfx is an unknown quantity at this point
I'm with Boosty.
I've been searching for month for wheel sizes that fits flush without spacers and body modifications and from the looks of it, s14hunter has it perfect.
SoundEfx is offline   Reply With Quote
Old 04-11-2016, 01:31 PM   #3560
[240sx]
Originally Posted by Black R View Post
...335/30/18's tucked on 18x12
18's look huge!!! Like the concept tho. :thumbup:
Old 04-11-2016, 06:12 PM   #3561
Black R
Black R's Avatar
^ thanks.
I'd prefer 17's, but a 17x12 is hard to find at a decent price.
I'd gladly move down if I could find anything reasonable.
Next up is fitting 335's up front.
Suggestions on what I'll need?
I think longer LCA's and upper camber plate relocation at a minimum.
Old 04-12-2016, 10:37 PM   #3562
Sumslapper
Sumslapper's Avatar
Sumslapper is an unknown quantity at this point
^ thanks.
Buy some 3 piece 17's and rebuild them to 17x12
Sumslapper is offline   Reply With Quote
Old 04-13-2016, 12:52 PM   #3563
silviaks2nr
silviaks2nr's Avatar
I guess I wonder why you need such a wide wheel and tire up front? I have a feeling it will just never work.
'98 240sx 5spd
kouki 2jz t56 swap build
Old 04-14-2016, 03:17 PM   #3564
Bubbles240
Bubbles240 is an unknown quantity at this point
s14
1996 Nissan 240sx with Enkei Kojins 18x9.5" +30 front and rear. No spacers at all with a 255/40/18 Falken RT615k in the front and a 275/35/18 Falken RT615k in the rear. Camber settings at -1.5 degree in the front and -1.0 in the rear.
Bubbles240 is offline   Reply With Quote
Old 04-14-2016, 03:31 PM   #3565
SoundEfx
SoundEfx's Avatar
Clean, tasteful and no irreversible body damage or modifications.
Well done sir, well done.
Old 04-14-2016, 03:34 PM   #3566
Bubbles240
Just painted a month ago as well.. Sad to see it go but I am moving out of the country for a while and I don't want to see this think collect dust.
Old 04-14-2016, 04:33 PM   #3567
SoundEfx
SoundEfx's Avatar
I'll keep it for you...
Old 04-14-2016, 04:35 PM   #3568
Bubbles240
Its in the for sale section.. send me some money and its yours to keep lol
Old 04-15-2016, 12:34 AM   #3569
Black R
Black R's Avatar
Because a square setup is fast for us grip drivers.
It's already been done - mostly street mod 240's running 18x12's and 315 Hoosiers up front:
http://nissanroadracing.com/showpost...&postcount=295
Old 04-15-2016, 02:01 AM   #3570
s14Art
s14Art is an unknown quantity at this point
Wheels: WORK VS-XX
Front: 18x9.5 et20
Rear: 18x10.5 et20
Camber:
Front: -3.4
Rear: -2.5
Tires:
Front: 275/35/18 TOYO R888
Rear: 315/30/18 TOYO R888
Body modifications:
Front: none, not even rolled
Rear: rolled and pulled
Would I do it differently if I were to do it again / next time?
Yes, 255 fronts and 305 rears... Also wish the wheels were about 5-7mm less aggressive, so I could run slighlt more positive camber without rubbing. But I'm not gonna get another set of wheels... These will stay on the car for a very long time.
s14Art is offline   Reply With Quote
