Old 05-07-2016, 05:31 PM   #1
JM216S14
JM216S14's Avatar
JM216S14 is on a distinguished road
Never hooked up to a ecu but I'm assuming you're using a laptop, did you try using a different com port? Or make sure nothing is using com port 3
JM216S14 is offline   Reply With Quote
Old 05-07-2016, 05:51 PM   #2
Brandeez
Brandeez is an unknown quantity at this point
Yes I'm using a laptop, I've tried in all 3 USB slots, only difference is it changes the code to COM3;COM4;COM5 depending on what slot the plms cable is plugged into.
Brandeez is offline   Reply With Quote
Old 05-07-2016, 05:55 PM   #3
JM216S14
JM216S14's Avatar
Did you download anythig new on your computer since you hooked up the first time? If not check google there is ways to see what's using the com ports. If nothing is using them sounds like you do have a cable issue maybe
nistune, sr20det
