#6181 | |
Gotta pay to play with this motor, people often look past this when starting and then we end up with lots of part outs
'98 Kouki Build in Progress '10 Subaru Legacy 2.5GT |
#6182 |
![]() Join Date: Sep 2011
![]() Feedback Score: 10 reviews
Lol i know this.. Haltech platinum sport 2000, id 1300, ball bearing gen 2 6266, and much more all purchased new. Ive lost count how much money ive dumped into my car. I spared almost no expense cosmetic and performance wise. Im just bored of the chassis and want to put the swap in something nicer than a 1991 240sx.l ive had the car for nearly 5 years, driving it around with the 2jz for 2 & 1/2 years.
Follow on Instagram For The Latest Imported Inventory!: @2JOHNZ_GTE |
#6183 |
Ok sorry for the long break there, i had an injector go out. Decided to just switch over to top feed and an aftermarket radiator. Starting upping the boost and at about 16psi i couldnt get traction in 3rd gear
![]() Anyway its still running hot after driving down the interstate for 30min and i have to pull over, especially if i get on it. I got rid of the crappy fan bracket/shroud and put the fans directly on the radiator, this seemed to slightly help. Added more cooling panels, and put on a turbo blanket which helped as well. Temps are still creeping, takes longer but still. I guess now its time for better fans since i just run dual 12in (?) Fans i got off summit.
S13- 2jz, 370z 6spd, PT6262 Nissan Master/GT-R Technician |
#6186 |
![]() Join Date: Oct 2007
Trader Rating: (53)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 53 reviews
This is what I have, but the SPAL's move more air. The problem with that particular SPAL setup is that it's not a slim setup.
https://www.flex-a-lite.com/electric...ctric-fan.html
#6187 |
![]() Join Date: Jul 2011
Does anyone use the B3 plug for the 2jz-gte vvti ecu? Looks like everything is for the automatic transmission other than pin 12 and 16, or would you recommend depinning automatic stuff?
Pin 12 is Exhaust Bypass Valve
Pin 16 is the Fuel Pressure Up Vacuum Switching Valve
![]() Better image: http://wilbo666.pbworks.com/f/131581...U%20Pinout.png |
#6188 |
Yeah i may have cheaped out on fans .... damnit. Went on a sunday cruise with a buddy today who has a 2014 camaro ZL1 with a cam, ported blower, head work and full exhaust on e85. He barely got me on a highway rip, with a little more boost and practice ill def get him lol. Coolant temps stayed around 200 today for that
#6189 | |
#6191 | |
#6192 |
I have a new pump on a fresh engine, no sign of air pockets and im not losing any coolant so i doubt its a HG. I run pusher fans and theres also a 4in thick precision FMIC out front, so the air on the hwy probably doesnt get thru the radiator so well. Its gotta be the cheap pusher fans or the KA koyo radiator ... or both.
#6195 |
^^^ he already knows what his problem is. Replace the KA radiator for one for an SR so that it forces the coolant to utilize the entire surface area of the radiator and ditch the pusher fans... I can't believe how many people are still trying to run pusher fans and then complain about them
#6196 | |
![]() Quote:
#6198 |
Anyone have a spare upper coolant neck from a 2jz i can buy $$$$$$??????? $$$$$$ I need to replace mine and go with a sr20 radiator amd crossover pipe
#6199 |
If you use a ka radiator you don't need that donkey dick of a cross over. Just trim the pipe so it's not bending that way.
#6200 |
Read the previous posts, i have a KA koyo rad. Some people have had problems not using a cross flow radiator. I already hacked my coolant neck which is why i need another.
#6201 | |
Haven't had any over heating or any cons of using a mishimoto ka rad. I had to switch rad caps to my old greedy one cuz it's stronger. |
#6202 |
#6203 |
![]() Join Date: Mar 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
2JZGTE Swapped S-Chassis thread
I'm actually running a derale pusher fan on my swap and that one single fan keeps my temps perfect in south Florida
#6204 |
#6205 |
Trader Rating: (53)
I'm gonna just leave this here: http://www.powerhouseracing.com/p-48...r-2jz-gte.aspx
Sent from my iPhone
#6206 |
#6210 | |
Yep [emoji16] that radiator, TRD thermostat, Toyota coolant/distilled water, and 1 fan keeps me cool Sent from my iPhone using Tapatalk
