Old 12-03-2004, 06:30 PM   #1
jononioo
jononioo is an unknown quantity at this point
No Cat... is this safe ?
i took my catylic converter off my 96 s14 and i was wondering if this safe for my engine. Some ppl are telling me that its fine for it and others are saying its bad for my engine b/c i have no back pressre so my valves will fry b/c they won't open and close when they should... will a knoledgable member of zilvia.net set the record straight!!!
jononioo is offline   Reply With Quote
Old 12-03-2004, 06:33 PM   #2
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
the only things its going to hurt is the air and your wallet if they catch you without it
wootwoot is offline   Reply With Quote
Old 12-03-2004, 07:04 PM   #3
S14DB
AFC #1
S14DB's Avatar
what did you put in place of your cat?
Old 12-03-2004, 07:12 PM   #4
kingsol
kingsol will become famous soon enoughkingsol will become famous soon enoughkingsol will become famous soon enoughkingsol will become famous soon enough
Send a message via AIM to kingsol
you'll be cool, but you have a test pipe right?
There is a time in every man's education when he arrives at the conviction that envy is ignorance; that imitation is suicide; that he must take himself for better for worse as his portion; that though the wide universe is full of good, no kernel of nourishing corn can come to him but through his toil bestowed on that plot of ground which is given to him to till.
-Emerson
kingsol is offline   Reply With Quote
Old 12-03-2004, 07:51 PM   #5
orion::S14
orion::S14's Avatar
It won't "burn your valves"...that's an old BS rumor.
(That *could* happen if you ran NO header, so open valves to the atmosphere...but NOT in your situation)
And you don't need backpressure...that's also a myth.
So...with all that said:
It's best to replace the cat with a test pipe or a high-flow...having just that big, empty area in your exhaust will slow you down. It needs to be smooth flow for high velocity...that is what's important. Not backpressure.
And for what it's worth: SCC gained HP and TQ by adding a high-flow cat to their project 240SX...
- Brian
www.KA24DEvelopment.com
Old 12-03-2004, 08:52 PM   #6
S14DB
AFC #1
S14DB's Avatar
This a 96 so the cat is in the downpipe not in the S13 location. That's just a holow shell.
Old 12-03-2004, 09:08 PM   #7
PinkPanther
PinkPanther's Avatar
PinkPanther is an unknown quantity at this point
Send a message via AIM to PinkPanther
KA
You're going to screw up the rich/lean cycles programmed into your ecu, b/c there is no change in 02 between the 2 sensors now. You might want to get a cat simulator so that your ecu doesn't throw a catylist failure code for im240 emissions testing(if you are required to do it).
The only reason you would NEED backpressure is if you have a positive backpressure transducer in your EGR system, but i'm unsure if the 240 has it or not. Have fun spitting hydrocarbons everywhere.
PinkPanther is offline   Reply With Quote
Old 12-03-2004, 09:27 PM   #8
S14DB
AFC #1
S14DB's Avatar
I have a OBX header which gets rid of the cat in S14's. My cat code get's throwen every 500+miles. Not a major pain. I still would like to know how he got rid of his cat.
Old 12-03-2004, 10:38 PM   #9
jononioo
nothing... there is just a gap between my cat and the rest of my exhaust sysetm
nope... not yet at least... will it still be loud with a test pipe...i kinda like it loud
.... im240 emissions testing(if you are required to do it).
..well, i just unbolted it from my exhaust... i don't get emmisssion tested where i live so the cat is just sitting in my garage.
Old 12-03-2004, 10:53 PM   #10
kingsol
hahaha you're crazy, your car will be stupid loud!
-Emerson
Old 12-03-2004, 11:09 PM   #11
PinkPanther
KA
I dare you to take your car to cali and drive it around San Diego and LA
Old 12-03-2004, 11:24 PM   #12
jononioo
no thanks man, i prefer not being behind bars
Old 12-03-2004, 11:27 PM   #13
mr_240sx
mr_240sx's Avatar
im running my sr20det with an apexi downpipe and apex'i n1 cat-back with no cat! its not any louder then the ka24 with a cat!
PS: ive had some people telling me that when they were following me that when i would shift, there would be a blue flame shoot out from the exhaust about 3 inches out !!!
mr_240sx is offline   Reply With Quote
Old 12-03-2004, 11:33 PM   #14
Var
Var's Avatar
Send a message via AIM to Var
so you're running open header? right?
Hi
Old 12-03-2004, 11:38 PM   #15
S14DB
AFC #1
S14DB's Avatar
so, you took out the fake cat or the real cat?
This is a fake cat on the S14's
Old 12-04-2004, 01:42 AM   #16
HyperTek
whatever u do.. maybe just disconnect the battery for an hour (resets ECU) so it will just reprogram to whatever it reads and adjust blah blah?? I know I said that a million times to people who installed intakes at my previous job and it works, so maybe this would clear up some of that sensor bs...
Keep it Classy
Old 12-04-2004, 03:20 AM   #17
kingsol
if you have no cat and nothing replacing it, you're running an open header, which means the rest of your piping, supposedly after the cat, is useless. i've driven to the exhaust shop once with an open header... it really is super hekka duper loud.
-Emerson
Old 12-04-2004, 09:43 AM   #18
mr_240sx
mr_240sx's Avatar
well where the cat used to be, i welded in a 3inch pipe so its pretty much a 3inch straight pipe!
Old 12-04-2004, 09:56 AM   #19
CA20Guy
CA20Guy is an unknown quantity at this point
Send a message via AIM to CA20Guy
you'll just lose some backpressure and get alot louder. cause your losing backpressure your power will decrease slightly ....but not much...
CA20Guy is offline   Reply With Quote
Old 12-04-2004, 10:10 AM   #20
Doriftomodachi
Doriftomodachi is an unknown quantity at this point
If you plan to stay with the ka with no cat but you want more power get the hotshot header. It gets rid of all cats (real and fake), flows smoothly and you will notice nice hp and torque gains.
Doriftomodachi is offline   Reply With Quote
Old 12-04-2004, 10:11 AM   #21
95Blue240sx
95Blue240sx's Avatar
95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection
I use to run the HS header in my S14 and it never threw a code. It's the same for the guy i sold it to.
Please leave me feedback
95Blue240sx is offline   Reply With Quote
Old 12-04-2004, 03:47 PM   #22
wootwoot
hp is not lost because of a lack of back pressure, and for some reason, the ka operates rather well in n/a form with no backpressure. in any situation back pressure does not make you lose power, it just ups your power band slightly, so technically you lose torque
Old 12-04-2004, 04:54 PM   #23
S14DB
AFC #1
S14DB's Avatar
Since I got the right map sensor on my car I have not thrown it. It's been over 600miles. When I was throwing the map code the cat code would throw. they could have been related.
was this a angled pipe. Cause the cat is in the DP and makes a 45 degree turn.
The DP with the cat is on the left. A test pipe in place of the fake cat is in the center and the cat back is on the right(black).
Old 12-04-2004, 05:17 PM   #24
mr_240sx
mr_240sx's Avatar
it looks something similar to that picture except for my downpipe connects to the new pipe completely straight and there are no bends in the pipe except for in the cat-back, which is a slight bend.
Old 12-04-2004, 05:50 PM   #25
S14DB
AFC #1
S14DB's Avatar
you do realize that what was in the place of the center pipe is Hollow?
Old 12-04-2004, 06:24 PM   #26
theicecreamdan
theicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfection
Send a message via AIM to theicecreamdan
no its not safe, you will kill all the plants and animals, all for a 2hp gain,
Originally Posted by malcolm_x
Be peaceful, be courteous, obey the law, respect everyone; but if someone puts his hand on you, send him to the cemetery.
theicecreamdan is offline   Reply With Quote
Old 12-04-2004, 06:50 PM   #27
ThatGuy
Admin Asshole
ThatGuy's Avatar
As long as you didn't remove the Muffler Bearings you should be ok.
Old 12-04-2004, 07:05 PM   #28
9524tee
9524tee is an unknown quantity at this point
Send a message via AIM to 9524tee
i have a hotshot header , which takes the "active cat" out , first off , and i have a enjukuracing testpipe , which replaced the dummy cat , and an hks hi power cat-back , its loud , and spits flames , but my check engine light has never come on , and it is so much quicker in the high end past 4k rpm,s ... hope that helps .
9524tee is offline   Reply With Quote
Old 12-06-2004, 11:34 AM   #29
CA20Guy
.....save the planet.
Old 12-06-2004, 11:55 AM   #30
Dream240
Dream240's Avatar
Not true, the HS header only removes the exhaust manifold and stock cat, not the hollow fake cat. You will need the test pipe mentioned above.
I went with the HS header, Random Technologies high flow cat, and the Apex N1 dual. I don't like the High flow-to-exhaust portion casue of the size differences. Eventually i'm gonna change exhausts to a Greddy for noise. Oh yeah and get new gaskets and mounting bolts taht way it will bolt up easily and clean.
