#61 | |
95 240sx RB20 415whp 91 Nx2000 VVL yo |
#64 | ||
#66 |
http://loj-conversions-llc.myshopify...smission-mount
Slight solution for the speed sensor. Personally, an app on my phone is better for me than this kit- but just wanted to show you guys what Sylas had found |
#71 | |
I know this is a CD009/CD00A thread, but I feel like we should bring up the difference in transmission models. Everyone seems to shy away from the earlier versions just because of the number on the side.
I'm personally using a CD001 transmission out of a v35 Skyline that has been upgraded with the CD009 synchros and throwout fork/pivot. Managed to get it cheap because of the number written on the side. The donor car had 60,000kms (40,000miles) when it was written off, and the internals look brand new (I was informed that the gearbox was rebuilt with the update kit not long before the car was crashed). From what I can tell, the biggest issue with the earlier versions has to be the weaker throwout fork and longer pivot flexing, allowing the synchros to wear prematurely. That and people not knowing how to drive a manual. Difference between throwout pivots: New: Old: I can't find images of the difference between the forks, but from what I have read, the earlier ones are weaker. Quote:
IIRC almost all of the transmissions made by Nissan prior to '99 used single cone sync rings almost exclusively. So as far as I'm concerned, there shouldn't be an issue running an earlier model 6 speed in your s-chassis as long as you use the upgraded throwout kit. Please make note that the Synchroniser rings are generally a brass item that is made to wear. They aren't meant to be smashed into gear, they work like a clutch plate to lock the gears onto the shafts slowly, preventing damage elsewhere. They are going to wear out eventually with each gear change. This would mean that a city driven manual box with 50,000miles would probably be in worse condition than a highway driven box with 80,000miles. TL;DR, if you want to drive like you're in the Fast and Furious, don't bloody whinge that your gears are grinding, buy a dog box instead. I hear Jericho's are cheap ![]()
Ziptie MS |
#72 |
I'm glad that someone finally compiled all of this information into one thread! I'm in the process of doing a CD009 swap using the Collins adapter. Keep the information coming!
#73 |
#74 |
![]() Join Date: Oct 2011
![]() Feedback Score: 27 reviews
Don't mean to thread jack, but does anyone out there have a spare oil gutter for a cd009(part number 32107-cd400)? They're discontinued and I misplaced mine!
This is what it looks like: ![]()
IG @jerry_beans_ |
#75 |
![]() Join Date: Mar 2009
Man I threw one of those away because I had no idea what it was or where it came from haha.
I've always been under the impression that you could not install a cd009 synchro set on an older model cd001-cd008 transmissions? |
#76 | |
So this is something I was waiting for! I got the email last night and purchased the shifter with the cross member. I had originally ordered the maverick motorsports crossmember, but decided to wait for this one. I'll post screenshots from the email gktech sent last night. ![]() ![]() ![]() ![]() ![]() Links in email: Here is a video showing the shifter out of a car showing how tight everything is: https://www.instagram.com/p/BFIfc6QHev3/ http://gktech.us7.list-manage1.com/t...5&e=49bd183cbb http://www.gktech.com/index.php/z33-...ion-setup.html http://www.gktech.com/index.php/z33-...arly-july.html
IG @jerry_beans_ |
#79 |
Yep I was just about to post up about the GkTech email haha! Since I already have the Mazworx crossmember with my bellhousing kit I'll just keep that one.
I'm going to order the GkTech Shifter, solid trans mount, Upgraded clutch pivot ball since the Mazworx bellhousing uses the Sr fork and pivot, and might throw in the GK billet shift knob too. Sent from my iPhone using Tapatalk |
#81 | |
![]() Join Date: Mar 2011
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 21 reviews
Looking to do a GPS sensor to my 95 S14 Stock Cluster?
DLG - DIRTYLOVE |
#82 |
A buddy and I were planning on running one from Amazon!
https://www.amazon.com/gp/aw/s/ref=i...sprefix=gps+sp
IG @jerry_beans_ |
#83 |
Just to post some more info in here, those of you using the Mazworx bellhousing kit MUST either change the pilot bushing in the crankshaft to the revised and shorter Nissan needle bearing, or cut the copper bushing shorter by 1/8". If not the transmission input shaft will bottom out in the crank shaft and potentially damage thrust bearings etc, even after trimming the input shaft stub in accordance with the kit instructions.
Also, apparently the Tomei stroker cranks require the pilot to be trimmed even further than 1/8" as the crank is not machined out as deep as an oem crankshaft. Meaning the needle pilot can't be used as it cant be trimmed. As far as I know nobody has tried it with a BC stroker crankshaft yet. Regarding clutches, the Mazworks bellhousing was built around a Comp triple plate clutch just to make sure that it should fit any clutch option you could possible have lol. |
#84 |
![]() Join Date: Sep 2008
![]() Feedback Score: 7 reviews
This gps signal converter needs no additional hardware. That means no Dakota box.
https://m.summitracing.com/parts/izl...FQYuaQodOfQD-g
#85 | |
DLG - DIRTYLOVE |
#86 |
![]() Join Date: Apr 2003
Trader Rating: (33)
![]() Feedback Score: 33 reviews
So I have searched high and low and have not come up with a clear answer. I know the CD009 can handle some good power but what is the "threshold" for it? I have seen them behind 1krwhp 350z in one video, behind an LSx in another, behind an 2J in another but again no clear indication to the sweet spot before it grenades.
#88 | |
Purchased this along with a Dakota Digital SGI-5 to convert the 8,000 down to a 2,000 Pulse. https://www.summitracing.com/parts/izl-s9020 ![]() https://www.summitracing.com/parts/dak-sgi-5e ![]() Will update when wired in and if it works.
DLG - DIRTYLOVE |
#89 | |
Awesome news. You should include a full write up so lazy people like me don't have to spend all day researching it. In other news Jason @ cbfperformance is doing a 50 order group buy on his rear mount shifter for $185. Let's support this American business and buy quality parts.
#90 |
Here's the group buy link
http://www.cbfperformance.net/store#...egory=19722030
