![]() Join Date: Aug 2015
Sr20 part out! A lot of aftermarket parts
All prices are best offer
Redtop sr unopened stock motor, Megan turbo mani $100 Isr rs3871 turbo $250 Hks Adjustable wastegate (12lbs) $80 Nistune ecu (stock flash by AVP in Tennessee) comes with consult cable $old Isis turbo elbow/downpipe $160 S14 sr water neck with coolant feed and tapped 1/8" for extra coolant sensor (currently plugged off) $85 Steel braided coolant and oil feed lines free with purchase of turbo S14 oem turbo oil return (brand new) free with purchase of turbo Heater core hoses modified using short NAPA coolant hoses (no behind head bs) S13 sr to S13 Wiring specialties harness $200 Isis rad with shroud and fans $260 Oem upper and lower coolant hoses $50 Isis intercooler with greddy flange $300 plus ship Exedy 3 puck clutch $300 Resurfaced oem flywheel Redtop ac bracket with codyace S13 ka swap brackets $200 When I swapped motor in I replaced the rear main seal, valve cover gasket, plugs, injectors, head to turbo mani studs/nuts and 7 layer gasket, mani to turbo gasket and studs/nuts with locking tabs, 5 bolt turbo to dp gasket and studs/nuts, new tps, new O2 sensor (fat), coolant heater core hoses, S14 oil return set up bought brand new, Car developed a misfire, replaced coil, plug, coil harness, and moved fuel injector, still missing in cylinder 4, I'm done with sr's going rb25, Update Motor runs. No misfire, but needs a lifter, rocker arm fell off intake cylinder 4, put it back on and it has a tap, but runs Sold Ecu Harness Thank you Cory (412) 480 1551 ![]() ![]() ![]() ![]() ![]() ![]() Last edited by Climb385; 07-11-2016 at 10:26 AM.. |
