Old 07-16-2016, 06:45 AM   #3
Mofuhcka
Mofuhcka's Avatar
Mofuhcka is an unknown quantity at this point
Originally Posted by David48 View Post
How did you test for boost leaks? When is it running 10.0 AFR? At idle, cruising, or under load?
Also, did this just recently start happening? Or is this a swap you just installed and are trouble shooting?
Idle and cruising. Under load goes lean. Sprayed all the couplers with starter fluid. When starter fluid goes in the system the idle drops
@hcr32love 400whp NEO R32 Sedan
Mofuhcka is offline   Reply With Quote
