Having SR Problems
SR is running weird, here is whats going on what I have already looked into:
Runs at 10.0 AFR Replaced maf TPS works Coolant temp works All spark plugs/packs are working Injectors aren't leaking O2 is replaced No boost leaks No old lines Ecu is throwing code but won't let me read it 1500rpm idle
@hcr32love 400whp NEO R32 Sedan |
![]() Join Date: Jun 2009
How did you test for boost leaks? When is it running 10.0 AFR? At idle, cruising, or under load?
Also, did this just recently start happening? Or is this a swap you just installed and are trouble shooting?
Idle and cruising. Under load goes lean. Sprayed all the couplers with starter fluid. When starter fluid goes in the system the idle drops
Do you have an adjustable fuel pressure regulator? Or if it's stock, have you tried another one? It's also worth opening the ECU to look for any burnt terminals or corrosion.
The FPR is working fine. Ill crack open the ecu
