08-03-2016, 05:24 PM | #1 |
Ls1/T56 Swapped 1986 Rx7 Fc
For sale is my 1986 rx7 fc for $5950 or best offer. This car was just built and has less than 100 miles on the freshly rebuilt motor. The motor and transmission are out of a 2000 F-Body, which has just over 75k on it to begin with, so the transmission has low miles. The car runs and drives great with no vibrations or funny noises. On to the specs.
1986 Rx7 Base Model, crank windows, hardtop. Turbo II 5 lug conversion Turbo II front 4 piston brake calipers Turbo II Brake master Turbo II clutch type LSD differential Aftermarket steering wheel Tanabe lowering springs with koni shocks Battery re-located to rear properly Mounted fire extinguisher Whalbro 255LPH fuel pump Corvette fuel pressure regulator Wilwood clutch master cylinder with braided lines and remote bleeder 2000 5.7L Ls1 engine Just Rebuilt including: New main and rod bearings New Melling oil pump New piston rings New valve stem seals New head gasket New gaskets everywhere New water pump 2000 t56 transmission with no grinds, pop outs, or funny noises of any kind Ronin speed works transmission and engine mounts Custom harness done by Ronin Ecu flash and tune by Ronin Aluminum driveshaft Monte Carlo radiator Two stage fan controlled through ecu (never overheats) Custom throttle cable and bracket Oil catch can Very nice custom dual exhaust settup, 2.5" from manifolds back to the x pipe, 3" dual from the x pipe to 2 magniflow glass packs, not the quietest settup but sounds amazing. Autometer oil pressure guage Autometer water temp guage Autometer speedometer (working) Factory tachometer and fuel guage working properly I'm sure there's more I'm forgetting. This car runs amazing and has a TON of power in a very light chassis. This car was built with the track in mind, so I don't have a title on the car. However, I will provide a bill of sale and I do have a bill of sale from the previous owner, as well as a California license plate for the car. The car does have some rust, nothing super crazy, I took pictures of everything I've seen on it. In my mind, this would be perfect to finish as a track car, or to re-shell your clean blown up fc. Of course it you were on a budget, you could register this chassis and have a fun and very fast street car. Pm, call, or text me with any questions. Phone: 6618587027 Faq: Q: Will you ship the car out of state? A: Yes, you arrange shipping. Q: Is it "BARD"? A: No. Q: Most other questions A: Please read the add, it should answer most of your questions. Last edited by culaphid; 08-04-2016 at 01:59 PM.. |
Tags |
fc3s, fd3s, ls1, rx7, swap |
