![]() Trans shifted fine for a good few months but all of a sudden, I lost reverse and then 2nd and 4th slowly started going. I can't get into reverse no matter what I do, here's the list of thing's I've tried:
#6 | |
I swapped in a bum transmission tryna replace the busted one. I feel your pain. Whys it so hard to find a good trans? |
i'll need to look into this.
bcuz everyone around here blows up their trans thinking they are keiichi tsuchiya lol |
![]() Join Date: Jul 2005
These transmissions are really simple inside
![]() There are only about 9 little tiny pez shaped pieces/springs. the rest is large rings, bearings/rollers, gears, shafts and bushings, stuff you can zip tie together for peace of mind. losing 2nd and 4th, only makes sense if the shaft itself moves, or something happened to the striker arm (lever that connects to shifter). As you can see in the pic, 2nd and 4th are separate gears. If you "lose" 2nd, you should lose first. and 3+4. |
Same thing happen to me was about to hit the hyways and shift from fourth to fith and heard a cracking noice fifth gear poped out and now the only that grabs is fourth gear replaced clutch tb and tried it and still has the same issue pulled the forck plastic cover to see if it pushes the clutch and it does it shifts it but wont grab the gears im totally lost now and dont know if anyone here had same issue at some point would like to know how they fix the problem or if any one has an idea sorry guys nooby here by the way is a ka any advice or suggestions would be much appreciated
#10 | |
http://www.americanpowertrainwarehou...issan-nis-23b/ |
#11 | |
