#1 | |
http://www.volkspage.net/technik/04/maximum_boost.pdf |
#2 | ||
![]() Join Date: Jul 2005
The best reason NOT to run a bypass/bov is for simplicity, when you have a car that absolutely needs the minimum (simplest) setup to win a race for $$$, so that there is less to fail/leak/go wrong. Like If I was going to race for pinks, blast the engine with nitrous/every trick in the book. Or a true race car, competition only, where you have 'unlimited' turbochargers, engines, and funding. Not having the bypass might mean lower wheel speed and more turbo wear, but if it guarantees that the shit isn't going to pop off, fail/lock open, or otherwise cause you to lose the race... its worth the additional drawbacks of having to change parts more often. BYpass/bov are best served in RELIABLE applications, mostly daily drivers, people who need to get 200k+ out of their setups. Quote:
The fewer quantity of air molecules between the wheel and the bypass the faster a similar diameter hole will be able to evacuate the plumbing and reduce pressure. Imagine a length of pipe extending from the compressor wheel outlet to infinity. Where would you plumb the bypass in this situation? At the far end, near infinity? The pressure would never drop in the pipe by the compressor wheel if you did that. On the other hand, If you place the bypass exactly near the compressor wheel, the pressure could stay elevated in the pipe at the length of infinity, while the local pressure by the wheel could be managed through the bypass, assuming the air does not flow backwards in the pipe (applicable to engines since they never breath backwards, there will always be some number of air molecules M traveling towards the engine even at idle speeds) |
#3 | |
#4 | |
You might get lucky but.... |
#5 | |
#6 | |
In short, any pressure spike seen near/at the throttle body is not going to increase wear and tear of any parts in that region. The part you are trying to protect is the compressor wheel. |
#7 | |
#8 | |
It wasn't necessarily the idea that you need to protect the TB or equipment, but moreso that the pressure wave would be caught early and dealt with prior to the shift event ending and the TB opening again. I am unsure of the speed of the pressure wave and whether it reaches back to the BOV next to the turbo quick enough to open the valve, vent the spike, and close before the exhaust is spooling the compressor again. Could this result in overspinning the compressor wheel? By that I mean, if the BOV is open and the turbo is being spooled could the compressor rpm spike without the pressure building in the IC plumbing? I'm just throwing my thoughts out here, not trying to be obstinate. There are a lot of things happening at this point in the cycle, and the fluid mechanics isn't a simple equation. I did well in Fluid Dynamics in college, but that was 10+ years ago and I don't deal with it regularly at work. |
#9 | ||||
