Old 12-23-2016, 11:01 AM   #4
1on1
1on1's Avatar
1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all
Really? If that part is replaceable then you should be able to find the part. Try searching in the FSM under Fuel Management to locate the part number and then call your local Nissan parts department with the number.
If the item cannot be replaced, and it's just a seal like the fuel pump opening, you can try the gas tank repair from your local auto parts store to see if that will work.
instagram
1on1 is offline   Reply With Quote
