![]() Join Date: Jan 2009
Trader Rating: (25)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 25 reviews
S14 SR20DET Notchtop Parts
I have a mostly compete notchtop motor I'm parting out. I'm not listing every single tiny piece so if there's something you are interested in, don't hesitate to ask. I will take pictures for you and answer any questions you have. I will also update missing pictures within the next day or two. The motor was rebuild and some goober put NA pistons in and it spun a bearing soon after.
Wiring/ECU: This is not available yet. It came with a WS Pro harness and ecu that I was told were for kouki motor/chassis, but everything I'm seeing says it's zenki motor/chassis, so I'm waiting to hear from WS for verification. Not Available/Don't Have: -Turbo-turbo mani-injectors Shipping: available at buyers expense S14 SR Block-$125-Was hot tanked, decked, and honed. The cylinders may need a slight hone again, which is why it's so cheap. ![]() ![]() Cyl 1 ![]() Cyl 2(That's a hair at the top, sorry, I should have wiped the cylinders out first) ![]() Cyl 3 ![]() Cyl 4 ![]() S14 SR Freshly Machined Crank-$200-Straight out of the machine shop. Was cut, polished, and balanced. As you can see, it will need .50 oversized rod bearings and .25 mains. ![]() S14 SR Head-$200- Was also hot tanked and decked. The VTC nose piece isn't pictured, but is included. All cam caps are included, and if my price is met all lifters and rocker arms are included as well. 4 Lifters were purchased new, each rocker arm was individually bagged with their corresponding shims. ![]() ![]() ![]() ![]() S14/15 SR VTC Gear w/ Solenoid & Bolt-$110SOLD ![]() SR ARP Head Stud Kit-$75-Torqued once. All washers and nuts are accounted for. Will include ARP main stud kit for $35 more. Main stud kit is missing one stud. I contacted ARP a while back and a replacement is $11. ![]() S14 SR Cam Angle Sensor CAS- $85SOLD ![]() ![]() S14 Water Pump w/ PC'ed Pulley-$35- Water pump is almost new. Includes the pulley which was powder coated electric purple ![]() ![]() S14 SR Alternator- $100-Was purchased new before the rebuild. In excellent condition.Will include bracket for $20 more ![]() ![]() S14 SR Power Steering Pump-$80- Will include bracket for $20 more ![]() S14 SR Alternator Bracket- $35 ![]() S14 SR Power Steering Pump Bracket- $35SOLD ![]() S14 SR A/C Compressor Bracket- $35SOLD ![]() S14 SR Starter -$90- Will have it tested for interested buyers ![]() S14 SR Front Cover/Oil Pump -$20-Clean. I'm pretty sure I have 3 of these. ![]() S14 SR Crank Pulley -$40- Includes brand new ISR Front Crank seal ![]() S14 SR OEM Lower Oil Pan- $35 SR20 Spec Stage 3 6-Puck Clutch-$175SOLD Plenty of life left on this. Includes TOB(not pictured) and pressure plate bolts ![]() ![]() ![]() SR ACT Lightweight Flywheel- $150SOLD- Will weight it tomorrow ![]() That's it for now. As I said before, I will update it with missing pictures and missing items. If you don't see it listed, feel free to PM me or post here. Thank you for looking.
![]() Last edited by Hoffman5982; 03-21-2017 at 08:12 PM.. |
#19 |
![]() Join Date: Aug 2005
Trader Rating: (18)
![]() Feedback Score: 18 reviews
Sent you a pm about the head and accessory brackets haven't heard back from you lmk
DON'T BE UPSET WITH THE RESULTS YOU GET FROM THE WORK YOU DIDN'T DO. |
#24 |
![]() Join Date: Mar 2009
![]() Feedback Score: 23 reviews
I PM'ed you about the block. I have cash in hand paypal ready
Do you need; Right side (USDM Passenger side) Replica S13 OEM Silvia Aero Bumper Grill S13 Silvia J's, Q's, K's, A's Bumper grill inserts. Male Plugs for S15 headlights PM me if you need them. |
#25 |
![]() Join Date: May 2005
Bump for legit seller... great prices, easy to deal with. Buy his stuff!
Got the VTC solenoid and sprocket from this thread in the mail today, installed it and worked perfectly! No more embarrassing hooptey rattle at startup and idle! Thanks Hoffman5982! |
#26 |
Still waiting on a reply about the block.
#28 | ||
Trader Rating: (25)
PM'd Quote:
