Old 03-23-2017, 12:07 PM   #1
coBBz
coBBz is a well-known jackass
Getting zero visible spark and where the hell are the cam and crank sensors I can't find any information on them..
coBBz is offline   Reply With Quote
Old 03-23-2017, 12:50 PM   #2
Gremo
Gremo's Avatar
Gremo can only hope to improve
Chase the spark issue first. Maybe there's a ground off the coil harness somewhere not attached. I'm not familiar with these motors but some do have an extra ground there.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Gremo is offline   Reply With Quote
Old 03-23-2017, 01:38 PM   #3
coBBz
Originally Posted by di-devol View Post
The crank angle sensor is lower left
1jz vvti IS an interference engine, you can butt-fuck the valves if the mechanical timing is off. Be careful.
Alright, Im going to take it out and test for continuuity and voltage after I get the coils to fire.
Didn't see any grounds there, but I might just give power through a switch to the injectors and coils if that would work? I'll also try and pick up a working igniter to rule that out as well and trust me man I'm sure you're 10x more familiar with this engine than me, I am lost lol.
Some background on the car just in case this might help..
Six years ago the previous owner had a running 2jzgte in the car and swapped it out for a 1jzgte.. Got the engine in and the harness done by Dr. Tweak in Phoenix, AZ. Harness came back and was never plug-n-play. After sending the harness back and forth the owner gave up on it and the issue was never resolved. Six years later, I take ownership of the car.. Harness is plugged up and the swap is complete, but still with the issue. Barely got it to crank a few days ago to check compression and all is good there. Some random relays here and there that I have no idea where they go, planning on removing these and anything unnecessary and wiring it up to it's original state before I start messing with it myself. Just trying to gather information on this swap because I can barely find any information about it.
I really appreciate the help here, I hope others can take something from this thread as well.
Old 03-23-2017, 02:00 PM   #4
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
Ew, might be time to just get a harness.
di-devol is offline   Reply With Quote
Old 03-23-2017, 02:07 PM   #5
coBBz
Trust me man, I want to.. badly but I have to give this one a chance and rule some things out before I drop a grand on a Wiring Specialties one. A lot of people say the 1jz ECU's like to shit on themselves too, so even if I get a new harness it still might not fire lmao lord help me
