#631 | |
#632 |
![]() Join Date: May 2006
honestly I want 600hp.
P11 VS. P12 cams. which one would be more sufficient in less lag and quicker spool.
#633 |
P12 are supposedly better.
However, if you want 600 HP either P11 or P12 will work or go spend $1000 on a set of Kelfords (which are out of stock until Nov direct from Kelford, although Mazworx should be getting new shipment shortly) |
#634 |
![]() Join Date: Nov 2012
![]() Feedback Score: 15 reviews
Why is there no love for 16ve cams? My head came with them so I'll be using them on my build....
Need UKDM/EUDM/JDM/RHD Nissan parts? Hit me up ![]() Insta: skids14 |
#635 |
EDIT: I will dig some of the info up on the ramps and such on the 16VE cams
In the meantime, this is a VERY good read! Lots of head and cam info (including info on ramp angles for the VE and why you can use the 16VE cam and not float stock SR20VE valve springs past 8000 RPM) SR20VE-101-The-good-info Last edited by RalliartRsX; 04-07-2017 at 09:44 AM.. |
#636 | |
![]() Join Date: Jun 2003
Trader Rating: (130)
#639 | ||
I'm not saying there aren't better options, but for most people in the 4-700hp world, 1k$ cams aren't needed.
#640 |
Kelford has several different cam options through Mazworx. It seems they were using the 20V low lobes and the N1 high lobes and 20V overlap (or something like that).
I wouldnt spend 1000 on those, but if I were to spend that kind of dough on cams, those are the specs I would shoot for if I want 600+ WHP. The N1s are great on high boost. |
#641 |
Isn't that the only type of boost? ;p
#643 |
Hey guys just to chime into the conversation, we are now dealing Kelfords directly as the US distributor that they were working with no longer plans to stock them. This means that we now can get cams usually in about 2 weeks if we don't have them on the shelf. We try to keep quite a few in stock though so if you're interested shoot us an email or give me a call!
#644 | |
#645 |
Hey man,
My name is Hanz (kinda like from Frozen & Star Wars (Yes I know that technically Han, but this helps people haha.) .) We actually just closed but shoot me an email [email protected] and I'll answer your questions 24/7 for the most part. |
#647 |
![]() Join Date: Apr 2013
I've commited to going the vvl route for my sr20. I've been doing my research on alot of build threads and online sources and believe i've come up with a decent 450-550hp build. I do have a couple questions if anyone can clear them up for me. Any recommendations/ tips/ advice and any positive or negative feedback is greatly appreciated.
S14 Block: Necessary machine work (deck, hone&bore, hot tank, balance rotating assembly, etc) CP SR20VE Pistons 87mm 9.0:0 comp. w/ gas ports Manley H-Beam connecting rods SR20VE Headgasket OEM S14 water pump Oversized water pulley Plug off unecessary holes on block Mazworxs timing mark relocation kit Tomei oversized oil pan Tomei oil filter relocation kit ACL wpc treated bearings ARP main & head studs P12 Head: Hot tank and deck Mazworx comversion kit Port & polish Cnc combustion chamber machining to 87mm Q45 Throttle body Denso IKH24 spark plugs Turbo: Full race top mount SR20VE exhaust manifold w/ dual wastegates Custom 3in elbow and downpipe Fuel: Mazworx fuel rail (in kit) All AN lines 255 walbro intake to bosch 044 external fuel pump Surge tank setup ID1000 fuel injectors I'm deciding between AEM pencil coils or IGN A1 coils but undecisive ao far. Any pros or cons Between the 2? Do you use the OEM SR20DET Timing Chain Kit with this setup? Very undecisive on a turbo, any personal recommendations ? I don't want to select a standalone until I find out what my tuner will recommend and is most comfortable with, but any recommendations on this as well or personal favorites with good amounts of failsafes ? Are any of the S13 guys running into any issuses with hood clearances? I have a dmax vented hood and curious if it'll clear or am i going to have to shave some off. Last edited by livelovesole; 04-30-2017 at 03:41 PM.. |
#648 |
I'd get 1300cc or larger injectors. You'll max the 1000's out on E85 around mid 500's. Sr20det timing equip will work fine. Make sure you have the proper spacer for the crank pulley.
A twin scroll setup would be the way to go if starting from scratch. If you have a single scroll manifold already, look at the EFR series turbos. The GTX turbos are good as well, if you are sticking around the 500whp mark. Some complain about the response of the 3076R, but this is a great turbo for strong mid range and top end. You'll suffer some spool over an EFR of similar size though. A GTX3576R spools like a 3076r but flows like a 35R. I recommend a Haltech unit. Designed around Factory Nissan sensors, which means less sensors needed for install. There is also no need for CAS modifications or additional trigger wheels or sensors, you get full 360* of resolution. I think you have quite a few unnecessary things. Port and polish and combustion chamber machining are not needed, especially with your power goals. I have a stock head, upgraded valve springs and make 485whp on 19-20psi. JE DET pistons in the 8.5:1 ratio will net you higher static comp than the VE pistons. They are also cheaper.
#649 | |
#650 |
has anyone had the denso pencil coils from mazworx fail on them? my car has randomly started misfiring but the mis fire goes away instatly once the car hits about 3k rpms..
my TPS is cracked and MAY not be functioning, but i don't think that could cause this mis fire? |
#651 |
Had my sr22vet on the dyno today.
667whp/555tq dynojet GTX3076r .78 twin scroll @ 30psi running 70% ethanol Pretty happy with the results, car ran 10.7 1/4 mile on Friday hopefully can get it down to 10.4 or so at this power |
#652 | |
![]() Join Date: Aug 2009
Trader Rating: (77)
![]() Feedback Score: 77 reviews
#654 |
The Sr20/Sr22vet thread
With torque being the issue for the clutch, I opted for the Comp twin disc and it's great on track, but I'd seriously consider the spec stage 5+ next time for the likelihood of a much smoother and more streetable feel with a significant torque capacity, but I haven't tried one yet and I don't street or track the car THAT often. It'd be nice if the car was a bit gentler on the stop & go stuff. I guess I'd expect that single to have a higher chance of overheating after some hot laps than the twin would, but that's pure speculation and I'm not out slipping the clutch a lot or kicking it like crazy either so it's a tough call.
Stiff coilovers, stiff mounts and a twin disc clutch are more physically demanding on me after cruising around for a bit, but they're amazing once you're out on track. Nice job btw candyred. What transmission and cams are you using? |
#655 | |
#656 | |
msglngth.......
#657 |
thats excellent. i'd love to see a dyno run! is your engine just sleeved and bored out or stroked also?
#658 | |
#659 |
I'm running aem ver 2 with aems trigger wheel
#660 | |
