Old 05-22-2017, 04:11 PM   #10
AceOfHz
AceOfHz is an unknown quantity at this point
My timing situation is explained in post #4 - Checked to make sure cam, crank, and distributor are all in sync and in the right place. Crank is at 0 degrees, key notch for cam is at 12 oclock, cam gear dimple is at 3, and distributor rotor points at #1 spark plug wire. This is correct timing if I read right. If it is incorrect or if there is something else I need to check, let me know.
I also just checked all spark plug wires to make sure they're all firmly seated. Cap and rotor are firmly screwed into distributor.
AceOfHz is offline   Reply With Quote
