#751 |
![]() Join Date: May 2006
all four or a piece
#753 |
![]() Join Date: Jun 2003
Trader Rating: (130)
cbr coils are dirt cheap on ebay
http://www.ebay.com/itm/2008-2016-HO...tY9Owq&vxp=mtr |
#754 |
![]() Join Date: Jul 2011
![]() Feedback Score: 7 reviews
I'm using those same CBR1000 coils in my Miata. Cheap. Runs well.
The SR20VET got IGN-1As for some serious spark.
My S13 SR Street Mod Build |
#756 |
Hey guys,
For the guys who use this thread to put together their wishlists I just wanted to mention that we've started anodizing our parts due to community demand, parts will also be laser etched in the near future. All VE swap and other billet aluminum Mazworx products will be available in clear, black, or purple at no extra cost. If there's anything else that the community would like let me know! ![]() |
#758 |
PM me, I have them in stock and can give Zilvia pricing!
#759 |
![]() Join Date: Apr 2013
Have you guys encountered any pros and cons using cbr coils and ign-1a coils? I'm a little stumped on which to get and can use the advice/ recommendation.
#760 |
The AEM, CBR and others of the same style are all Denso Coils.
I have not had an issue with my CBR coils. I originally had AEM COILS, but couldn't justify spending the money on one coil that I could get a set for.
#761 |
Considering I'm multiple thousands of dollars into my VET, saving ~$150-200 by going with CBR coils instead of IGN-1As didn't seem to be a big deal to me. I was already blowing out LS coils, so I figured I'd just go with the strongest and be done with it forever.
The CBR coils would probably work, yeah, I just wanted that extra insurance. If I had gone back to the dyno with the CBR coils and had blowout again, I'd have been pissed.
#762 | |
#763 | |
#764 |
#765 |
hanz that's a bone stock p11 head?
#766 |
That was a bone stock P11, the P12 flows no better (depending on casting quality give or take 5 CFM.). The P12 intake port simply looks more efficient due to the shaping of the area around the fuel injector. This is why we always recommend the P11 head because they're cheaper, more accessible, and have a vast aftermarket where the P12 has non of those advantages.
We'll also be flow testing the DET heads at variable port "stages" to show that the money is better invested in the VE. Intake manifold testing is also on the schedule to show advantages of various designs in numerical values no simply theory. |
#767 |
i wonder what cfm's a ported p11 or p12 get after a full porting job done.
#768 | |
#769 |
#770 | |
#771 |
It's great you guys have FINALLY acquired a flowbench. I had mine done years ago, so nothing new to note on the numbers you've produced. However, I'm very interested to see what a ported head, in their various stages, can produce. There is a bunch of mixed information on what a well ported P-head can flow.
#772 | |
![]() P.S Just saw flow numbers of a stock P11 head with stock IM vs GATO manifold. Summary of results: stock IM sucks (on a bone stock NA setup) ![]() ![]() |
#773 |
So I've just got my car tuned and dynoed. It's pushing about 260 rwhp, running on a stock turbo and boosting 1.2 bar. Is this roughly the figure I should get on this setup? Or should I be seeing higher figures? Let me know if I missed out any info
Mods are: CP VE pistons 86.0x9.0:1 Spool Con Rods P11 head and cams Supertech valve train ID 725 injectors walbro 255 pump stock turbo 1.2bar |
#774 |
#775 |
Hanz., are you going to flow test a P12 Head as well
#776 |
Well due to the lack of them on hand, especially any with work done I don't see that being done anytime soon. I can tell you that it would flow within 2-3% of the P11 though. They're not what the internet hypes them up to be.
#777 |
I was looking for stage 4 flow numbers so i can compare mine later on
#778 | |
Also, as we have mentioned (hanz and I), lb for lb for P12 head does not perform much better than the P11, especially if you "upgrade" to P11 (int) valves. One of the reasons the P12 flowed more was due to the int valve stem diameter being .5mm thinner than the comparable P11 in addition to 30mm exh valves on the P12 vs the 29mm on the P11. |
#779 | |
Another downfall to the P12 head is that you can't get our awesome 8 injector billet intake that utilizes a single rail to fit (spoiler we're making 1 piece billet lower intakes for ALL SR20 platforms now, pictures coming soon, also they will be able to be anodized as well, mic drop.) |
#780 |
Hanz, what was the exhaust side flow numbers on that head? If anywhere needs work, it would be on the exit side of the head to increase velocity through the head. That would aid in spool up tremendously.
Just so people are aware, this is a 90mm bore drawing these numbers. A smaller cylinder is going to effect overall numbers. Any chance you have a standard bore to produce numbers on? I understand you've probably CNC'd the combustion chamber for this head. However, it would be beneficial to have numbers on a head that doesn't go "balls to the wall". Keep me posted on the development of your "product" you contacted me about. I will need some lead time to get the car to you and square some things away with you guys.
