Old 07-19-2017, 04:51 PM   #1
Fraskie
Fraskie is an unknown quantity at this point
Nah, but i un-plugged the 02 sensor and the car will crank as much as i want. But once i plug it up it doesn't start. I'm gonna try the o2 sensor when i get paid Fri
Originally Posted by evilpanamajack View Post
Have you checked compression?
Fraskie is offline   Reply With Quote
Old 07-19-2017, 05:11 PM   #2
OutlawLui
OutlawLui's Avatar
OutlawLui is a well-known jackass
damn that's weird. Considering It's a single wire O2 sensor with not much voltage signal
I believe new should be like $6
or pull some from the junkyard
OutlawLui is offline   Reply With Quote
Old 07-20-2017, 06:00 AM   #3
Fraskie
Yeah, a new one from autozone is like $16. We're also going to use a multi-meter on my TPS and check my fuel pressure. So ready to fix my car!!
Old 07-24-2017, 01:27 PM   #4
Fraskie
Yo, so check this out. The 02 sensor on my car doesn't match any 02 sensors at any part store whether it is a KA24E or KA24DE.
Help? Mine is much larger than the ones i've compared it to. The engine is a KA24DE in a 1990 hatch chassis. The wire connector to the 02 sensor is the flat style.
Any advice/help towards the right 02 sensor would be appreciated.
Old 07-24-2017, 02:20 PM   #5
OutlawLui
OutlawLui's Avatar
pics? this is the once i got a while back
part # 11027
you have to cut the wire from your old 02 and crimp it on this new one
Simple single wire
