It's actually opposite. By not running a thermostat, there's nothing to keep the engine running at optimum temp. This would be really noticeable on cold days when the coolant is flowing through the radiator unrestricted, the engine may actually never reach op temp. Basically the thermostat keeps the engine running at op temp, opening as needed.
#2 | |
![]() Join Date: Nov 2012
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 7 reviews
no. without a thermostat your engines temprature will be controlled by the ambient temprature and may never reach operating temprature on the streets. and on really cold days would be stupid low temps
The Game you lose haha |
#3 | |
Just tossing this out there because my buddy had this issue one time and after a few hours of checking basically what everyone has said already I was checking all the hoses and one of the hoses that he had used to bypass his heater core had a small kink in it restricting flow, it was very hard to see but once I changed the hose with one that fit better the temps were a-lot better after that.
#5 | |
the heater bypass hose that bypasses the thermostat willc ause you to overheat if its kinked but it will stop overheating when you pull the thermostat
I see yea i don't have any kinked hoses, im starting to suspect the worse HG issue, going to try to do a leakdown test as soon as i can cause that's really the last thing i expect it to be at this point unfortunately
#8 | |
![]() Join Date: Mar 2015
Ive got a circuit sports fan controller and im seeing temps for a short drive 15-20 to work I get to around 84c(183) regularlly on my drive to work in the morning. Then when I go to school about 10 miles away taking mostly I highway I hit 90-94c(194-201f) always and if Im driving a lot it will creep up to 95-97. Also noticed if I drive and let it cool down then go to start it sorta like when I go out to our meets, hang out for a few hours and start the car but dont turn on the fan once it hits OP temp at 70-74c I will wait a bit and my temp gauge on the cluster is reading fairly hot and my gauge looks to be lagging behind. I did notice im not getting a reading on one of my probes for my fan controller. So could be my temp for oil is 194-201f which is normal for oil being 10-20 degrees warm than coolant or maybe my oil temp gauge got damage when I replaced the filter recently... The wires are so brittle. First I'll see which sensor im reading, switch to water wetter and distilled instead of 50/50 mix and get one of those coolant funnels since i've herd good things about those. ![]() |
