Old 12-28-2004, 04:03 PM   #1
sepulchral
sepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymore
When i press clutch all the way down, gears won't change
I just changed the clutch and bled the lines (not the best bleeding though)
if i press in the clutch pedal half way i can switch gears, all the way and it doesn't do anything, what might be wrong?
sepulchral is offline   Reply With Quote
Old 12-28-2004, 09:21 PM   #2
WeldingHank
WeldingHank is an unknown quantity at this point
you need to adjust the pedal.
WeldingHank is offline   Reply With Quote
Old 12-28-2004, 10:34 PM   #3
max_misawa
max_misawa is an unknown quantity at this point
Is this while the engine is running???
Max
max_misawa is offline   Reply With Quote
Old 12-28-2004, 11:34 PM   #4
sepulchral
asdfgsdf
yes while the engien is runnign
Old 12-29-2004, 09:32 AM   #5
BIGBX1
BIGBX1's Avatar
BIGBX1 is an unknown quantity at this point
How does the clutch pedal feel? Did you try and bleed the system by yourself or did you have someone pressurize the pedal and then crack the bleeder on the slave cylinder open,Also check the pedal adjustment.I hope this helps some.
BIGBX1 is offline   Reply With Quote
Old 12-29-2004, 10:41 AM   #6
SilviaSativa
SilviaSativa's Avatar
SilviaSativa is an unknown quantity at this point
I had the same problem.. Keep bleeding!
If you want to make it easy on yourself remove this secondary bleeder box crap, it'll take a fraction of the time. It goes from like 3/8" brake hose to a huge 1/2" loop, no wonder it's such a pain in the ass!!
SilviaSativa is offline   Reply With Quote
Old 12-29-2004, 12:53 PM   #7
sepulchral
i had already removed the damper box. i bled the car again and the problem went away thanks
