Old 11-09-2017, 05:48 PM   #1
kyral
kyral's Avatar
kyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nice
Originally Posted by EnnEssEnnKAT View Post
Yes that piece. The coil bracket must also be grounded to the chassis there i think
Sent from mTalk
was your issue a very intermitent misfire? cause ive been running this setup for over 2k miles and it only recently started acting up and its very inconsistent
I ask cause i did a lot of re soldering of the harness and removing cracked and corroded wires, but before i repaired the harness i had actually used it in its poor condition and it ran the car just fine before i repaired it. so i know it can run with some heavy corrosion (injector connectors were heavily corroded and it still ran well, tho i did replace them)
that spade since its heavily insulated is quite well protected against the elements and i know mine didnt show any fatigue on the wire sheathing and there was no visible corrosion so id think that to be very unlikely but ill try and check it
The Game
you lose haha
kyral is offline   Reply With Quote
