Old 01-23-2018, 10:29 AM   #1
RalliartRsX
Trader Rating: (32)
RalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfection
Feedback Score: 32 reviews
Originally Posted by TheRealSy90 View Post
Do you personally tend to go to the looser or tighter side of the tolerance?
Depends on end goal. Lots of track use (trackdays, long drift session) slightly looser in general terms due to the major buildup of heat and expansion
JE pistons has all the calculations and recommendations on their site. Just select which piston and it should have all the info (including bearing clearance if you also bought their rods). There is some math involved which take into account bore dimensions for instance.
RalliartRsX is offline   Reply With Quote
Old 01-23-2018, 10:59 AM   #2
Garage Skidz
Garage Skidz is an unknown quantity at this point
Thanks all for the replys. Im probably going with the .017 top and .018 bottom gap. that should be good for 15 to 20 psi with a 2871r for street use.
Garage Skidz is offline   Reply With Quote
bearing clearance, built sr20, piston rings, rings, sr20det
