#8 | |
i just google image'd "power steering reservoir" and found a couple that look to be of decent quality, but i'm only judging based off their aluminum finish and price :P http://www.kse-racing.com/shopexd.asp?id=108 looks decent and has dual filters https://www.turnone-steering.com/col...inum-reservoir i run a turnone rebuilt ls1 p/s pump in my ls1. it was highly recommended to me, so i assume the reservoir is also of high quality. the reservoir has an internal "tee baffle", whatever that is. any input on either one of those? also, could you measure the capacity of that new KRC one that you have? alsooooo, you mentioned your prototype reservoir not having a filter. i was planning on running one of these Cardone filters if i ended up going with the stock s13 reservoir, since apparently filtering your p/s is a thing (i had no idea). Cardone PNs = 20-0038F, 20-P038F, 20-0012F, 20-0058F dibs on your prototype? :P hey Poorman, wasn't codyace running a cooler on his p/s setup and still having issues with "strawberry milkshake"? right? i just read all 13 pages of it on NRR...so apparently just slapping a cooler doesn't necessarily fix that problem. although........it seems that his issue was from debris getting stuck in the "main pressure fitting and the flow control valve" |
