08-21-2018, 07:30 AM | #1 |
Alternate a/c compressor solutions for sr20
In the process of revamping my ac system. Currently have brand new lines, drier and expansion valve from Nissan, can’t buy a new condenser anymore. Debating whether to flush my current condenser or just buy a new generic condenser and have lines made/adjusted. Only issue I’m running into is what a/c compressor to go with. If it matters, I have a 180sx with the same redtop sr, ac went out a couple years ago. Kept popping the ac fuse by the driver side kick panel. Never figured out the issue.
Has anyone tried other Nissan a/c compressors? Went to autozone last week and a 2000 maxima compressor lines up with the holes on the redtop bracket but the pulley alignment looked off a little. It’s also a 6 groove pulley vs the stock 4 groove. I don’t really want to buy a reman compressor if possible. Any input would be greatly appreciated. |
08-21-2018, 12:27 PM | #2 |
I would love to find out about this as well. I've researched for a while now and I've made lines and still have my blacktop compressor. The only this is I have never tried to get installed in my car. Maybe someone has done it and can give out some information.
08-21-2018, 12:37 PM | #3 |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
i have an SR compressor if you want it... ill let it go for $200 shipped. it was pulled from a working SR some 9 years ago. i purchased it from a member on Zilvia, never installed it. has been sitting in my garage ever since.
08-21-2018, 12:43 PM | #4 |
I am not sure that's what he is asking........
08-21-2018, 01:35 PM | #5 |
ITS LISA'S FAULT!!!
Trader Rating: (41)
just throwing it out there... i forget i have the silly thing most of the time. if he wants it, its there for him. SR compressors arent easy to find anymore
08-21-2018, 01:46 PM | #6 |
Gonna have to pass. No way to determine if the compressor will last.
On topic, did some research and from what I’m seeing the s13 ka compressor will bolt up using the front two bolts and belts be lined up perfectly. Using that information I cross reference the mounting distance off rockauto to match another compressor from a 2000 Nissan Frontier, this is also a 4 groove pulley but the pulley has a slightly bigger diameter. The pulley diameter and port closest to the pulley are my concerns as of now. Edit: Decided to go ahead a purchase the compressor and lines. Should be here by this weekend. If all fits good, I can get the lines made asap. Last edited by xpinoyxmk; 08-21-2018 at 05:28 PM.. |
08-21-2018, 05:48 PM | #7 |
When I swapped my s14 sr into my s13, I just unbolted the compressor from the ka and put it to the side. Then when s14 sr engine was in I bolted it on and yea I think it was 2 bolts don't remember. I Didn't discharge the ac or anything, everything worked great for 2 years and the person I sold it to, has not has not had a problem since.
08-27-2018, 05:39 PM | #9 |
I'm getting my AC set up with a S15 compressor, which turns out is the same body as a 2001 sentra sr20 but different pulley. I haven't done any junkyard measuring to see what pulley setup can be used, but I'm pretty sure that a RWD pulley will work. I'm making lines from the S15 and my old S13 lines, so not a bolt-in affair... but fairly simple after I had figured out the little parts.
Lots of people in my area have S15's (and lots were getting 2JZ's), so it's a matter of what was available. |
08-27-2018, 09:17 PM | #10 |
that's awesome, fab work with welding a/c lines shouldn't be an issue as the maxima lines are available from autozone or the junkyard! I may recommend some fab work to my buddy who as been asking about getting this to work in my swapped fc too!
08-28-2018, 08:06 AM | #13 | |
08-28-2018, 08:07 AM | #14 | |
I don't think there are r12 and r134a specific parts for these cars. |
08-28-2018, 10:16 AM | #15 | |
My logic tells me there has to be though since they made s chassis cars until the 2000's. R134 cars run at different pressures, require bigger fans, better condensor etc, so I doubt they're all still rocking old r12 parts. (unless the parts work for both, which you would suck) I wonder if anyone sells parallel flow condensers for these cars? This is why I bought a couple of cans of r12 incase the silvia's ac ever messes up I can just fix the leak and fill it with the right amount of r12. |
08-28-2018, 10:36 AM | #16 |
https://www.vintageair.com/builder-series/
May have parts and pieces, depending on how serious you get.
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 | |
08-28-2018, 11:50 AM | #17 | |||
Four Seasons 68428 - Compressor Four Seasons 56132 (low) and 55089 (high) - For the fittings on the ac compressor |
08-28-2018, 05:31 PM | #18 | |
06-07-2019, 03:29 PM | #19 |
Quick update for anyone wanting ac during this hot ass summer.
Yesterday I got the lines made, bolted everything back in, vacuumed, added 5oz of pag 100 and charged the system with 24oz of r134. My car was in the shade and from my little rc temp gauge, the air temp was blowing in the mid 40s. Today, I started the car after it had been sitting in the sun all day. Inside temp was 100+ (Black car/black interior) and after running for about 5 minutes, the temp blowing out the vents was low 60s. My 17’ F150 was blowing the same fyi. My low side ended up between 35-40 and high side was around 175-185. Outside temp at a little above 80 degrees at the time. As far as I researched, I am good to go. Can anyone here confirm this? |
06-09-2021, 03:39 PM | #21 |
Little update for those that need ac like me.
Had a tiny pinhole leak in one of the welds on the line that runs from the firewall to the compressor. Not sure how I didn't notice it for so long. Had the weld redone, recharged the system and its been blowing cold for almost 2 months now. |
08-24-2022, 08:46 AM | #24 | ||
Wait, didn't you have an S14 or S15 200SX sold straight from the factory? That should be all you need, or are those parts discontinued? Quote:
I think '94-up 180SXs are R134a, also, not sure when Japan phased it in for the home market. |
09-02-2022, 08:54 PM | #25 |
A little relevant, but I was able to find a universal condenser that fits the S13 for the people that need that part of this puzzle
Vintage Air 03701-OVA Just posted a little write up in my thread for anyone interested in how I mounted it: https://zilvia.net/f/showpost.php?p=...8&postcount=37
IG: de_guzzi // Build Thread |
09-17-2022, 11:45 AM | #26 |
Safe bet this works on KADEs as well?
http://www.nissanroadracing.com/ |
09-20-2022, 07:38 PM | #28 | |
The lines still have their OEM routing and positions; they just terminate to the universal condenser's new fittings
09-29-2022, 09:21 AM | #29 |
I recently just purchased a R134a from a low mileage car. I'm getting very close to finishing 2D drawings for this. Need to get the side brackets done and then the side,top views and dimension it out. Will dimension the side brackets and metal bases as well. It will be pretty in depth.
Do you guys think with the dimensions we could maybe find someone who can make these? I'm not too familiar with the process but I would think it would not be outrageously expensive since its fins and bends of lines? Was just wondering you guys think? Around 300-500 per condenser maybe? Would be nice if it was lower but I dont think that will happen. Vintage Air will make hardlines for you if given the dimensions so I was planning on remaking the 240sx oem A/C hardlines from the condenser to the drier and condenser to the compressor with the possibility of using a different compressor than the KA one. I'm hoping someone on here will chime in as I do not want to resort to asking these questions on facebook or reddit. Realizing at this point those places are useless
Instagram: Nismo_Lk |
10-01-2022, 02:24 PM | #30 |
Making new custom parallel flow condensers (supposed to be more efficient) is a thing that can be done. This particular shop doesn't offer the service anymore but they did, and it landed right in your price ballpark:
https://www.originalair.com/custom-p...ce-17-condd-ca S14 OEM condensers were already parallel flow style. If it is more efficient, then I'd expect a slightly smaller universal one like DEGUZZI used should be OK. I also wonder about the R32 OEM condenser 92110-04U02. It's been re-issued as part of the heritage parts program and seems to have the same dimensions as the S13 condenser, the upper connection is in the same place, but the lower connection is moved to the other side along with a bracket to mount the receiver/dryer in front. |
