Old 11-12-2018, 07:32 PM   #31
PoorMans180SX
PoorMans180SX's Avatar
Originally Posted by spooled240 View Post
Looking to either:
1)Reflash the JWT ecu for bigger injectors(740cc), the lower compression(9:1) and the Tomei cams. I believe this service is about $100?
2)Get the AEM v.1 EMS going with larger injectors, LS coil packs and a GM map sensor. Will have to get the car dyno-tuned of course. This route is much more expensive, but the car will be dialed in perfectly and will be faster.
3)Do #1 first and #2 later
I say keep the JWT ECU or go to a system like AEM infinity, or preferably a Link G4+ ECU. A 64-pin SR ECU should plug in, you'll just need to move to a coil over plug igniton.
AEM V1 flat out sucks, and V2 is okay but tends to have a lot of problems with trigger issues and is generally slow in comparison with modern ECU's like Link, Haltech Elite, and Infiniti. My
Old 11-16-2018, 11:47 AM   #32
spooled240
spooled240's Avatar
spooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfection
Why do you say the AEM v1 sucks?
It seems like it's pretty much an OEM KA/SR ecu with more support for coil drivers and a map sensor. I know it's pretty basic especially compared to what's available nowadays, but I was under the impression that it would be more than enough for my goals.
If it sucks because it's unreliable and slow like an old computer from the 90's then I guess it is a problem lol
spooled240 is offline   Reply With Quote
Old 11-16-2018, 12:01 PM   #33
MiamiGrinch240
MiamiGrinch240's Avatar
MiamiGrinch240 is an unknown quantity at this point
The biggest problem you will find with AEM V1 & V2 is support. They are both outdated & should anything become damaged on them, you’re screwed as there will not be replacement parts for them. On top of that, should you have a harness designed to plug into them, now you will have one more thing to replace. “Budget” & “Standalone” rarely belong in the same sentence.
98 S14 SE KA-T (Original Owner)
Founder of SFL240SX
MiamiGrinch240 is offline   Reply With Quote
Old 11-16-2018, 05:40 PM   #34
PoorMans180SX
You nailed it, haha. Serial cable communication takes ages, no live tuning, limited tuning flexibility, etc. It's just not something I would ever pay for. I would 100% run a Nismotronics board over V1, and probably V2. So that's another option for you.
Modern ECU's are awesome because the inputs and outputs can often be reconfigured, there's tons of compensation tables for everything you need to make the car super driveable and reliable, and you can tune them live because the processor is actually from this century hahah.
Old 11-22-2018, 05:30 PM   #35
CalebS13
CalebS13 is an unknown quantity at this point
Megasquirt PnP. not a bad option for “budget” standalone imo. planning on purchasing one for my KA-T soon.
CalebS13 is offline   Reply With Quote
