Old 02-08-2019, 07:03 AM   #1
silviaks2nr
silviaks2nr's Avatar
I don't have any good in process pics unfortunately. It's a tricky retro because the rear portion of the housing has to be cut out and rebuilt to accommodate the projectors (the bulb sits in the center instead of offset to the bottom like stock). I actually ended up having to tig weld custom brackets to use the original pivot/aiming points as the factory reflector. The light output is far superior to most OEM projectors, definitely mini h1, with good width and a nice centralized hot spot that fades to each side. They accept any OEM d2s HID bulbs/ballasts as well which is a huge plus. The projectors are from TRS.
Hope this helps!
