Old 01-13-2005, 10:05 PM   #1
nissan_drifter
nissan_drifter is an unknown quantity at this point
HVAC lighting?
My heating/air control lights all work, except the direction buttons/defogger indicator, etc... Though when the car warms up it seems fine, it still comes to be very ficke though, I pulled the unit today and all connections seems good, no loose wires, nothing inherently wrong with the unit itself, any ideas?
nissan_drifter is offline   Reply With Quote
Old 01-13-2005, 10:19 PM   #2
Toahk
Toahk's Avatar
Toahk is an unknown quantity at this point
Send a message via AIM to Toahk
Haha same with my car, you just have to memorize the sequence. I think it goes from right to left. Top air, top air and feet, feet only, something I don't use, then the extreme left is the window defroster. Or just turn on your little light. But as for your problem, sorry I dont have any recommendations to fix it.
formerly Norcal_Drifter
http://www.cardomain.com/id/toahk
Toahk is offline   Reply With Quote
Old 01-13-2005, 10:25 PM   #3
projectRDM
projectRDM's Avatar
Replace the bulbs.
FORMERLY R240NA
Old 01-13-2005, 10:47 PM   #4
nissan_drifter
how would I go about replacing the bulbs?
Old 01-13-2005, 11:06 PM   #5
mrmephistopheles
mrmephistopheles's Avatar
pull out the HVAC controls and unscrew the bulbs. it's not rocket science - it takes 20 minutes. or less.
*kicks Russ*
Originally Posted by PHLIP
Old 01-14-2005, 12:06 AM   #6
driftyour40
driftyour40's Avatar
driftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the rough
I just did a quick search and found a lot of good info but the one thing that I didn't find was where to find the bulbs. People did it with ones from radio shack but said they didn't fit right but made it work. So I was wondering if Nissan sells the bulbs or not? If not I’ll just buy a new unit all together one of these days.
driftyour40 is offline   Reply With Quote
Old 01-14-2005, 06:51 PM   #7
Ghettokracker71
Ghettokracker71's Avatar
Ghettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enough
Send a message via AIM to Ghettokracker71 Send a message via Yahoo to Ghettokracker71
Mine have been burnt out too. It doesn't take long to memorize the layout...
Ghettokracker71 is offline   Reply With Quote
Old 01-15-2005, 02:21 AM   #8
idlafie
idlafie's Avatar
Bulbs are replaceable...you can get them from Nissan
Part #'s
27545-50J00....short bulb...you'll need 3
27545-50J05...long bulb...you'll need 1
Taking apart the Heater / AC Control Panel only requires three small jewelry type screwdrivers and a pair of needle nose pliers....Easy to do...You'll have to pop the Dial button off along with the Push buttons from the front of the unit. Then you'll have to gently pry the retaining tabs away from the case as you remove the back faceplate. Then loosen a wiring harness, pinch 3 plastic tabs then gently remove the electronic circuit board to get to the bulbs. I've done it so many times it's second nature now. If I ever figure out how to create a webpage & link the photos to it, I'll post a DIY page on swapping out those bulbs...
ID
Old 01-15-2005, 02:24 AM   #9
idlafie
idlafie's Avatar
*kicks Russ*
On a S13, piece of cake...S14...pain in the ass!!.. You gotta take apart the Heater/AC unit on the S14. On a S13 the bulbs are easily accessible. Sometimes I wonder what the hell those friggin IDIOT Nissan engineers were thinking when they designed some of that sheyat!!...
ID
Old 01-15-2005, 10:57 PM   #10
DaPCWiz
DaPCWiz's Avatar
DaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond repute
Send a message via AIM to DaPCWiz Send a message via MSN to DaPCWiz Send a message via Yahoo to DaPCWiz
hmmm good info. imma have to use this to fix my hvac too....
http://blog.dapcwiz.com
DaPCWiz is offline   Reply With Quote
Old 01-16-2005, 06:59 PM   #11
AllenRPS13
AllenRPS13's Avatar
AllenRPS13 is an unknown quantity at this point
i got the same problem on my s13... but i am too lazy to replace them, haha
~小アレンのリベリオン~
いくせ, 勝負た! 轟こう, オレのKRMS13!!!
オレの得意技!蹴り進入!角度の少ないドリフト!
AllenRPS13 is offline   Reply With Quote
Old 01-16-2005, 10:26 PM   #12
Rownan
Rownan is an unknown quantity at this point
Send a message via AIM to Rownan
Easy to replace, hard to get ahold of the bulbs, unfortunately.
It took my local Nissan dealer 2 weeks to get all 4 bulbs for me.
Rownan is offline   Reply With Quote
Old 01-16-2005, 11:44 PM   #13
240silvia
240silvia's Avatar
240silvia is an unknown quantity at this point
Send a message via AIM to 240silvia
Every 240 I have had has been different..... first one half of them lit up, 2nd 240, none of it lit up.... now this one... they all work!
240silvia is offline   Reply With Quote
