Old 01-21-2005, 04:16 PM   #1
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
infinity kappa 6.5s in the s13 door
Yup they sound dope. They're the 3ways, I got em off ebay for around $120 shipped. I made some plexi baffles to mount them in and just wanted to share a few pics I snapped... BTW the plaid lookin stuff is 1/8" thick foam tape, it's on the back side of the glass. It causes the plate to seal good against the metal door skeleton, and the foam also eliminates any resonance they might have otherwise....
They sound 1000 times better than the blown 4x6 shit that was in there. They clear the window and door panel with ease. I'm sure someone out there is thinking of doing something like this too, I say go for it you will not be disappointed.
MELLO*SOS is offline   Reply With Quote
Old 01-21-2005, 04:22 PM   #2
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
Is anyone interested in a set of rough cut 1/4" plexi baffles? I made four and used two, so I have a set of rough cuts if someone wants em. You still need to sand down the edges a little (use a dremel with drum attachment), drill mounting holes (marked) and cut out speaker hole (I didn't cut because u might wanna go with 5.25"s instead) and drill speaker mounting holes............ PM if interested.
Old 01-21-2005, 04:41 PM   #3
CKAMC
CKAMC's Avatar
CKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfection
hmm i have done that already... infact i put in the perfect 6.1's in the front... any plans on doing the same mod to the back 4x6? if you do manage to to get 6 1/2 to fit in the back 4x6 slots then i will be sure intrested in buying the plexi baffles from you
CKAMC is offline   Reply With Quote
Old 01-21-2005, 04:57 PM   #4
rancid240
Trader Rating: (72)
rancid240 will become famous soon enoughrancid240 will become famous soon enoughrancid240 will become famous soon enough
Feedback Score: 72 reviews
looks good...might have wanted to go with components though.
This has been done numerous times but we usually use crap like I did (its not even MDF, i dont know wtf it is but it sucks)
rancid240 is offline   Reply With Quote
Old 01-21-2005, 05:16 PM   #5
Dutchmalmiss
Dutchmalmiss's Avatar
Dutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfection
Send a message via AIM to Dutchmalmiss
how much would you sell them for? i'm interested and sick of the 4x6's as well!
Pignose, biaaatch.
Dutchmalmiss is offline   Reply With Quote
Old 01-21-2005, 05:22 PM   #6
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
Thanks for the comments
I am going to ditch the 4x6s in the back. I have an idea on how to put 6.5s back there, but it needs some more think time. I haven't even really examined the back area yet, but what I'm thinking of right now would move the speakers out of where they are now in the fastback.
Regarding components, of course I would love to have a set of decent components up front. In fact originally I wanted to do a 3way setup by building some glassed kicks for some 4's and tweets and 6.5s in the doors. There is very little foot room as is, so with that in mind I went this way. At best I'll mount a set of tweets up front either in the door panels or glassed into the a-pillars. I am not building the car to win any sq contests, and frankly this ride really isn't worth a crazy install. I do love listening to music while I drive about so this suits my needs perfectly...
The only other things I want to do audio wise are a glassed box in the rear right in the trunk, with a single 12 and ~500w amp to drive it. I might try going with a new-to-me respected brand, something like an adire brahma or shiva.... Perhaps a 4ch amp to drive the fronts and rears. Perhaps sirius... My plan is to eventually install the kappa 6.5 three ways in the back as rear fill, and replace the fronts with 6.5 components and tweets as described above........
What material did you use if it's not MDF or plexi? I used plexi since the door gets fairly wet during the rain and MDF would probably rot or fall apart after a few years. Also the plexi is 1/4" not 1/2" like the MDF, since I knew door panel and window clearance might be an issue. The plexi is strong, easy to work with and thin so it has lots of clearance...
Old 01-21-2005, 05:32 PM   #7
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
What up dutch
I will take some pics tonight for you to see. Basically they are just like said above, so you know you'll need to do *some* work on them. They are DIY style
- sand edges down (i'll scribe the line from my template so u know where to sand to)
- drill four bolt holes to mount baffle (i'll draw center marks)
- cut out hole for your speaker. Mine needed a 5" hole and I adjusted the ring (front/back + up/down + clock) so that none of the screws would touch the metal door skeleton..
- drill holes to mount your speaker.
Tool wise for a minimum you'd need a drill, and a dremel. I'll even send u a bunch of the foam tape I used, u can cut it and apply it to the back to make em seal up well against the door...
How about I'll ship em to you for $25? edit: I see you're in Eagle Rock, by glendale/silverlake right? I'll deliver em this weekend for that price. PM me if you're interested..
Old 01-21-2005, 05:59 PM   #8
Gjohnson7
Gjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura about
Nice!!!! I'll be doing this shortly with componets, but I plan to run 6 x 9's in the back, built into the top of my 10" sub enclosure. Should sould great reflecting off the hatch glass.
LSX Kouki Project, swap completed in Dec 09
Gjohnson7 is offline   Reply With Quote
Old 01-21-2005, 07:21 PM   #9
HyperTek
so what if dust/water get on the rear of teh speaker?? reason i didnt make my own plates was becuase the speaker will be shooting towards your feat.
I cut/hacked the stock plates adn stuck 5 1/4 inifiniti woofers and warpped em in speaker baffles, then tweeters on the door covers.
Keep it Classy
Old 01-21-2005, 10:58 PM   #10
kazuo
kazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enough
I have the same setup in my car. I love it. Nice mids but no low end of course... I need a sub. ugh
Lucky for me I have a coupe so I have 6.5 all around. Sounds DOPE.
kazuo is offline   Reply With Quote
Old 01-22-2005, 09:38 AM   #11
CKAMC
CKAMC's Avatar
hmm well let us know how the 6 1/2 change works out for the back! I have a FB and well its hard to fix people who have moded them.
Gjohnson7: when you put in your 6x9's mind showing us a couple of pics? do you plan on inserting them into the rear deck?
I myself hope with the help of some of yall to be able to place 6 1/2 where the rear 4x6 go and place in some 6x9's in the rear deck and have a 400-500 watt amp to throw in some extra power
Old 01-23-2005, 10:47 PM   #12
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
They make these foam baffles that you can install with the speakers. Everyone (crutchfield, partsexpress, etc) seemed to be backordered on them when I put this together, so I don't have them... yet. I think it would be very very wise to have them, since I did some of this work after driving the car in pouring rain, and yes it gets "very" wet in there...
The speakers obviously aren't aimed very well but they still sound alright.. 5.25s sound probably close enough to the 6.5s anyways neither have much bass especially when they're crossed over. I thought about using them too, I like that you recycled the stock plastic baffles
