#1231 | |
![]() Join Date: Jul 2011
![]() Feedback Score: 7 reviews
![]() Anyway, I've had it inspected before, just gotta find understanding shops. Been sitting a bit and may last one has since expired so I have to take care of that again. I mean, it can out brake and out steer 99% of cars on the road, it's very safe in that regard and meets the requirements for lighting and all that but I've had shops just look at it and say no. Being an 89 helps at least, it's emissions exempt. I'll shoot you a DM.
My S13 SR Street Mod Build |
#1233 |
Another trackcross event complete. Car did well, however on long sweeping or high g left handers, the car just completely dies for 2-3 secs.....which cost me a top 6 easily. Car made is the almost 200 mile round trip plus how many track miles.
Going to drop in the N1s, keep the boost @ 14 on the 7163 and go have some fun. |
#1234 | |
![]() Join Date: Jun 2003
Trader Rating: (130)
#1235 |
So I was recommend on Holley HydraMat. I had the ECU failsafe for oil pressure as well. However, was unable to setup data log before or during the event (long story). So I am not sure if it's fuel starvation or ecu failsafe or both. Tough to glance down at the race dash when trying to hang on because #stockseat
![]() I am "guessing" fuel starvation as if it was an oil pressure issue, I figured it would occur on both right AND left handers (the custom oil pan baffle, designed off the old Jun drop in stock pan design, is symmetrical on both sides). We will see ![]() Will probably throw in the hydramat and see. Tough to test on the street however as there is no way in hell I am going to be full send on any on ramp ![]() |
#1236 |
Sounds like fuel starvation.
I doubt you're going fast enough in corners to cause oil surge unless you're on slicks? I run a basic surge tank setup and that eliminated all fuel surge issues for me. IO was getting fuel starvation issues even with under 200rwkw and on semi's in my CA s13. You can carry more fuel to get around it but the weight can make the car more rear biased. |
#1237 |
^^ I am going to grab a holley hydramat. Thanks for reminding me!
So.........anyone else want to report on thier setup?? I see a bunch via insta, but build threads seem to be a thing of the past.... |
#1238 |
My setup is currently being bead blasted before the build begins. Head, Block, Crank all passed inspections.
Builder was very happy with the block/crank, but I hunted around specifically for something that had a very minor failure (cracked ring land) and no bearing failure on a virgin block. |
#1239 |
Nice!
I am awaiting to hear back from my cage builder as I am planning on getting a half caged installed. Next; fixed the shifter popping out of the shifter cup, fuel pickup issue, diff swap to S15 diff, and clean up IM. But mostly drive! |
#1240 |
I did the s15 diff swap when I swapped subframes, made a big difference to rear end grip.
Very happy for the minimal $$. I went a little custom and retained my CA crown and pinion and used just the helical centre. |
#1241 |
My build thread was systematically destroyed by Photobucket... On other news, the car is now located in Pa which I am stoked about. Time to get to work.
#1243 |
^^ I hope to do the same. Turns out the AL fittings don't play well with PS fluid so I have all new PS lines and Steel fittings to fix.
I think I am on the Def train. The N1 may perform much better than internet/drag racing wisdom |
#1244 |
Everything I’ve seen that compares the VE cams shows the true value of them. I’m looking forward to getting mine swapped over and re-dyno’d.
#1245 |
Jr. You are in Philly about 2 hours north of me! When and where are you planning to dyno?? I usually take my vehicle to JK tuning in Carlise. I have a roll bar and a few odds and ends planned for March in preparation for the first track day in April. At some point between now an then, I would like to make my way up to JK for a new tune with N1 cams, E85 and a boat load of boost and drivability and track day tune.
Let me know how your schedule shakes out. There is another SR Z32 (no VE however), I will also be planning to meet up with to lend him a hand in a few things Cheers! |
#1246 |
Pics have started coming in from the builder.
This is after glass bead blasting. Next step is final acid wash/pressure wash with bungs etc removed and we can start the build. https://imgur.com/a/XlMRxX5 |
#1247 |
Hello everybody . I'm looking for information. Who uses Brian crower valve springs BC1030 in their construction? I wonder if they are reliable for 8500 RPM ? . have offered me a new game at a good price
Thanks you |
#1248 |
I’d use Supertech over BC. Supertech has been know to use superior metal.
#1249 |
#1250 |
I’ve never used Kelford springs so I can’t comment on them. Honestly, I haven’t looked into springs in years. With that said, beehive springs are used in the Honda and Mitsubishi world prevalently with large success. Keep in mind, the lower spring rating of the Supertech springs is sufficient to prevent valve float in higher rpms while also minimizing unnecessary premature wear of valve train components.
#1251 |
1. Link NS15 G4+ plugin ECU with external Link E-Throttle module
2. Bosch Motorsports 60mm TB 0280 750 151 but VW/Audi 1.8t TB also works, both TB bolt onto DE/DET with M8-M6 thread reducing inserts 3. 350z throttle pedal assembly with sensor 350z pedal cut off south of hinge and bend, Stock Schassis pedal welded on Chassis throttle stopped extended to reduce travel. Would be nice to see more S chassis owners playing with DBW For VE builds I guess it would simplify certain aspects, with no throttle cable and no IACV/wiring needed. |
#1252 |
#1253 | |
i am looking for supertech or kelford dual (which uses retainer stock apparently) |
#1255 |
Hey guys I have a stock P12 head lying around and most components to do a RWD VET. Power goal is ~500-550 if twin scroll Gtx 3071r allows it. Competitive drift car, fast spool time is a plus.
I have N1 intake and a normal non-N1 sr16ve exhaust camshafts on the P12 head. What do you guys think of this combination? with this small turbo. With this camshaft combination would I need VE pistons? I have all stock valvetrain on the head, what would you guys suggest to change/upgrade? Thanks |
#1256 | |
what fuel you run will have a big effect on your power goals. if this is a track only car, set it up and tune it for 110 or e85 and you'll get to that 500whp much more easily than a street car tune on 91 octane. |
#1257 | |
What about that camshaft combination and having all stock valvetrain? |
#1259 |
![]() Join Date: May 2006
since you guys are talking about pistons, what would be the perfect pistons to use high comp or lower comp for e85 and methanol?
#1260 |
High comp on E85.
