Old 05-31-2020, 01:16 PM   #1
S14rebuild
Did you do a full resistance sweep of the tps? Could have a dead spot.
Old 05-31-2020, 01:30 PM   #2
Shirohige
Shirohige is an unknown quantity at this point
Ye i did. It goes smoothly from 0.45v to 4.2 or something. No dead spots
Shirohige is offline   Reply With Quote
Old 05-31-2020, 07:01 PM   #3
zombiewolf513
zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513
Originally Posted by Shirohige View Post
Sounds like a tuner should correct your fuel settings then. Ill try that too very soon. Found out today that my spark plugs had a layer of oil on them and the spark plug wells had oil too. Looks like the valve cover isnt seated properly so ill get that shit done tomorrow
Edit: i also read a bit of the FSM today and they covered hesitation part. Said to disconnect your FPR vacuum hose and see if it still hesitates. And to pinch the hose that goes to the pcv and see if that fixes the problem
Are you sure its oil on the plugs and not a layer of wet fuel on a carbon fouled plug? I found the same things, but i think the plugs might have fuel on em. Found this too:
https://youtube.com/zzMagT5rVMA
I tried the fpr hose and pcv hose things, no change there for me though. Interested to see what you find.
s14rebuild is talking about testing the resistance, not necessarily the voltage sweep. Mine was sweeping voltage eh alright but was really f'd on a resistance test. Vid of the testing:
https://youtu.be/6SR0oIuC0z4
Changing the tps didnt resolve the issue on my end. Coil packs tested to spec @ 1ohm
OP: is your o2 feedback idle control turned on in your commander? When was the last time you replaced manifold injector oring seat things?
zombiewolf513 is offline   Reply With Quote
