Old 01-20-2005, 10:10 AM   #1
joel
joel is an unknown quantity at this point
Send a message via AIM to joel
I cant get this damn thing to run right! help!!
hey,
i have a 1991 240 coupe that i havent been able to really drive for a good 5 months because its been having some problems. If you could help that would be awesome.
ok. so when i first start the car up after its been sitting for awhile, it cranks like a champ. no problems. Now, if i were to crank it and say let off the starter to soon and try to start it then most likely it wont crank. it will just keep trying to crank and trying to crank and if i do it long enough then it slowly acts like the starter diisconnected from the flywheel like the engine doesnt even shake or anything. i dont know what that is about.
but whenever i try to start it and it doesnt i smell fuel pretty badly.
Oh and when i am driving at really low rpm's the car is buck alot back and forth. It just seems like no matter how long i drive it whether it be 30 min. or 1 min if i turn it off it wont start back. please help if at all possible. i really want to drive my baby soon. thanks in advance. joel
joel wikle
joel is offline   Reply With Quote
Old 01-20-2005, 12:49 PM   #2
89s132b
89s132b is an unknown quantity at this point
Most likely, you have leaking fuel injectors. Pull them out and check the o-rings. Just replace all the o-rings while you are at it.
You probably get black smoke and poor gas mileage too?
89s132b is offline   Reply With Quote
Old 01-20-2005, 02:05 PM   #3
joel
yea,its getting pretty shitty gas mileage im not sure about the smoke. do you think that is what it is? what all do i need to remove the injectors?? thanks
joel wikle
Old 01-20-2005, 02:46 PM   #4
s13irdie2
s13irdie2 is on a distinguished road
check your fuel filter also.
1990 s13
IslandMotorsports, Inc.
s13irdie2 is offline   Reply With Quote
Old 01-21-2005, 02:38 AM   #5
idlafie
idlafie's Avatar
Check your fuel pressure regulator on the fuel rail. Hook it up to vacuum gauge and see what pressure it's at while at idle. I think it should be at 35 psi.
The attached links give more info...
http://www.tradervar.com/Fuel%20Syst...%20Testing.htm
http://www.stcloudchampionauto.com/pdf/57_PressReg.pdf#search='testing%20fuel%20pressure% 20regulator'
http://www.directdiagnostics.co.uk/t...uel%20flow.htm
Anyhow...hope this helps..
ID
PS:
If you figure out the problem, can you please post the cure....thanks!!
Old 01-23-2005, 12:53 PM   #6
joel
what all tools do i need to remove the injectors and check the fpr ?? does anyone else have any suggestions while on working on it?
joel wikle
Old 01-24-2005, 05:33 PM   #7
joel
bump bump
joel wikle
Old 01-25-2005, 08:36 AM   #8
the head
the head's Avatar
have you looked under the hood yet the removal is rather straightforward go buy a chiltons manual to help you out
Old 01-25-2005, 09:38 PM   #9
doainwpg
doainwpg is an unknown quantity at this point
either buy a chiltons or download the fsm from here http://www.zeroyon.com/TheSite/techservice.html
Life's the race everyone's dying to win
Free Ipods Here
doainwpg is offline   Reply With Quote
