Old 01-26-2005, 08:52 AM   #1
HATchTRICK
HATchTRICK's Avatar
HATchTRICK is an unknown quantity at this point
Turbo Selection.
Is this turbo a good choice a S14 sr. The motor is basically stock with 3" exhaust, z32MAF, 740cc injectors, greddy intake manifold, power fc, and top mount manifold. I am looking to go for 400HP for now then over next winter build the motor and go for over 500hp. Should i go with this Turbo or just get the t3/t67 now and end the questioning?
COMPRESSOR SPECS:T04S
flow: 61 lbs/min 781cfm
.70 A/R housing
60-1 TRIM wheel
TURBINE SPECS:T3
.48 A/R housing
HIGH FLOW 76 TRIM stg 3 wheel
oil lubricated centersection.
due to large compressor flow internal wastegate option is not available.
COMES STANDARD WITH 360 DEGREE THRUST BEARING!!
HATchTRICK is offline   Reply With Quote
Old 01-26-2005, 09:57 AM   #2
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
I like the new gt series turbos by garrett. Should throw cams in the mix as they help a whole lot out too. Is this going to be straight up track car or what? If street/strip I would take a gt3071r with the 1.06.
There is new technology out there, might as well use it ya know?
wootwoot is offline   Reply With Quote
Old 01-26-2005, 11:15 AM   #3
HATchTRICK
HATchTRICK's Avatar
The car is not gonna be daily driven, btu ti will see the 1/4 mile track on the weekends. I want something that will give me the power i want for now and i can always upgrade later on.
Old 01-26-2005, 11:42 AM   #4
Var
Var's Avatar
Send a message via AIM to Var
@ 61 lbs/min it should make a lot more than 400hp when you need it to.
Hi
